    Display switch from Pixel to tty1 after manual installation
    bootdisplaypixel
    11 Posts 6 Posters 4.1k Views
      ttoine
      Hello,
      A few info:
      • Raspverry PI 3
      • Raspbian 4.4 with Pixel
      • Alim Aukru 5V 3000mA
      • Sandisk SD Card 64Gb cat.10
      • RetroPie 4.2
      I did a manual install of RetroPie, and everything is working, I can run emulatiostation from the command line.
      The only issue I have is that since, the PI boots to Pixel desktop, and then the display switch like if I would do ctrl+alt+F1.
      How can I fix that and stay on the desktop, so I don't have to do ctrl+alt+F7 manually?
      Then, my aim is to follow this guide in order to add a link in Pixel's menu, so anyone can launch emulationstation without command line:
      http://aoakley.com/articles/2016-12-29-raspberry-pi-retropie-pixel-desktop.php
      RascasR 1 Reply Last reply Reply Quote 0
      • RascasR
        Rascas @ttoine
        @ttoine Can you run this, it is a fix that we use on PiPplware distro to fix something like that:
        sudo sed -i 's/fbi -T 2/fbi -T 1/g' /etc/init.d/asplashscreen
        This might bring other problems, but if solves your problem, maybe we can find something that works for any boot cases.
        To reverse it, you can do:
        sudo sed -i 's/fbi -T 1/fbi -T 2/g' /etc/init.d/asplashscreen
          BuZz administrators @Rascas
          @Rascas showing the splash on tty2 is an old default. If everything works as it should on tty1, I'm happy to change it. I can't remember if there was a specific reason for that or not.
          • herb_fargusH
            herb_fargus administrators @BuZz
            @BuZz possible it had something to do with video splashes but someone would have to test to verify. I wouldn't know either way
              ttoine
              @Rascas thanks, it works. Should we open a bug or an improvement request for the manual installation documentation?
              What kind of problem could this bring? what should I check?
              • jkwattJ
                jkwatt
                i have the same problem.
                afther i install retropie manually on my raspbian the autostart don't work good, i try to give the command you list over but dont work.
                this is what i have in terminal:
                Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Tue Mar  5 10:22:10 2019
                pi@raspberrypi:~ $ sudo sed -i 's/fbi -T 2/fbi -T 1/g' /etc/init.d/asplashscreensed: impossibile leggere /etc/init.d/asplashscreen: File o directory non esistente
                pi@raspberrypi:~ $ sudo sed -i 's/fbi -T 1/fbi -T 2/g' /etc/init.d/asplashscreensed: impossibile leggere /etc/init.d/asplashscreen: File o directory non esistente
                • RascasR
                  Rascas @jkwatt
                  @jkwatt The file to edit/sed is now /opt/retropie/supplementary/splashscreen/asplashscreen.sh
                  jkwattJ 1 Reply Last reply Reply Quote 0
                  • jkwattJ
                    jkwatt @Rascas
                    @Rascas tankyou for the answer but for me don't work, sorry but i'm a beginner with retropie
                     pi@raspberrypi:~ $ sudo sed -i 's/fbi -T 2/fbi -T 1/g' /opt/retropie/supplementary/splashscreen/asplashscreen.sh
                    pi@raspberrypi:~ $ sudo sed -i 's/fbi -T 1/fbi -T 2/g' /opt/retropie/supplementary/splashscreen/asplashscreen.sh
                    pi@raspberrypi:~ $ sudo reboot
                    Am I doing something wrong? thanks for the help !
                    • RascasR
                      Rascas @jkwatt
                      @jkwatt Just run this once:
                      If you run the other one, you are putting it back as it was, the original state. I think it is well explained in the earlier replies.
                      jkwattJ A 2 Replies Last reply Reply Quote 1
                      • jkwattJ
                        jkwatt @Rascas
                        @Rascas thank you very much, forgive me but as I told you before I'm a beginner with retropie. and I get a bit of confusion with English, thanks again, now I have my raspbian with retropies + all the raspbian tools including arduino
                          AnjunaBeats @Rascas
                          @Rascas i have the same problem...
                          i run this :
                          And works 100%..
                          but ...What does that line of code do?
                          ty.
