    Raspberry PI 3 B on CRT TV through A/V input
    video output
    14 Posts 4 Posters 5.0k Views
      Kecha
      alt text http://imgur.com/a/Wz725
      So, when i connect the A/V cable to the Tv this is what it looks like, the TV its NTSC/ATSC and try like 100 ways to fixed without result , here is the config.txt
      force_turbo=0 #Enable cpu-overclock over 1300MHz (default 0)
      #avoid_pwm_pll=1 #Enable no-relative freq between cpu and gpu cores (default 0)
      #arm_freq=1300 #Frequency of ARM processor core in MHz (default 1200)
      #core_freq=550 #Frequency of GPU processor core in MHz (default 400)
      #over_voltage=6 #ARM/GPU voltage adjust, values over 6 voids warranty (default 0)
      #sdram_freq=575 #Frequency of SDRAM in MHz (default 450)
      #sdram_schmoo=0x02000020 #Set SDRAM schmoo to get more than 500MHz freq (default unset)
      #over_voltage_sdram_p=6 #SDRAM phy voltage adjust (default 0)
      #over_voltage_sdram_i=4 #SDRAM I/O voltage adjust (default 0)
      #over_voltage_sdram_c=4 #SDRAM controller voltage adjust (default 0)
      gpu_mem=256 #GPU memory in MB. Memory split between ARM and GPU (default 64?)
      #gpu_freq=550 #Sets core_freq h264_freq isp_freq v3d_freq together (default 300)
      #v3d_freq=500 #Frequency of 3D block in MHz (default ?)
      #h264_freq=350 #Frequency of hardware video block in MHz (default ?)
      #dtparam=sd_overclock=75 #Clock in MHz to use for MMC micrSD (default 50)
      dtparam=audio=on #Enables the onboard ALSA audio (always use this ON)
      dtparam=spi=on #Enables the SPI interfaces (default OFF)
      temp_limit=80 #Overheat protection. Disable overclock if SoC reaches this temp
      initial_turbo=60 #Enables turbo mode from boot for the given value in seconds
      hdmi_drive=2 #Normal HDMI mode. Sound will be sent if supported and enabled (default 2)
      #hdmi_ignore_cec_init=1 #Avoids bringing TV out of standby and channel switch when booting (default 0)
      #hdmi_ignore_cec=1 #Pretends CEC is not supported. No CEC functions will be supported (default 0)
      #hdmi_force_hotplug=1 #uncomment for composite PAL (default 0)#sdtv_mode=2 #Pretends HDMI hotplug signal is asserted (default 0)
      start_x=1 #Enable software decoding (MPEG-2, VC-1, VP6, VP8, Theora, etc. default 0)
      overscan_scale=1 #Video Output will respect the overscan settings (default 1)
      disable_overscan=1 #Disable overscan configuration. Set 1 if you see black lines on TV (default 0)
      disable_splash=1 #Avoids the rainbow splash screen on boot (default 0)
      #avoid_warnings=1 #Disable warning squares (Red=over-temperature ; Rainbow=under-voltage). (default 0)
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=256
      • funkybunchF
        funkybunch
        How you connect the Pi3 with the CRT? With a HDMI > composite cable?
        I don't know much about this, but i think there are better solutions with native 15khz support.
        Something like that?
          Kecha
          Nope , the devices is conected to the Tv with a 3.5mm to A/V cable https://www.amazon.com/Parts-Express-3-5mm-Plug-Cable/dp/B0007V6JCK
            edmaul69 @Kecha
            @Kecha red is probably video and yellow is right channel audio. Most of these cables have those two backwards.
              Kecha @edmaul69
              @edmaul69 tryed every possible configuration, and yes, is the red one, but this is something with the config.txt that I cant get, not the cables, im using the system of "aikoncwd-rpi-mediacenter" but this problem happens even with NOOBS
                edmaul69 @Kecha
                @Kecha have you tried just using the retropie image thats available on this site instead of noobs and the other one i never heard of? Also make sure you dont have an hdmi cable plugged in
                  Kecha @edmaul69
                  @edmaul69 tried with raspbian , noobs, this one mentionet, kodi, retropie, etc and nothing
                    edmaul69 @Kecha
                    @Kecha if you use the retropie image on here and posted the config.txt i could help you. Im not familiar with other images.
                      Sturo
                      @Kecha I ran into a similar issue. I ordered a cheap cable off of Amazon like you did (it might be the same one), and I tried everything, only to find out that the cable was bad. I ended up ordering this one and it worked like a charm.
                        edmaul69 @Sturo
                        @Sturo i use an xbox 360 e slim cable. Both are made by microsoft. Both are good quality. Far better than those cheap cables.
                          Sturo
                          @edmaul69 Yeah about the only good thing to come from the Zune was the A/V cable. That thing is pretty solid, and the colors match up, yellow is video, white and red are sound.
                          edmaul69E K 2 Replies Last reply Reply Quote 0
                            edmaul69 @Sturo
                            @Sturo same with the xbox 360 e slim cable. Correct colors. I owned a zune. The original Green one. I had the cable for it too. I had repaired a couple for a friend of mine. As far as ipods and zunes at that time i preferred the zune. The iphone and ipod touch changed what i use though. I am an iphone guy now.
                              Kecha @Sturo
                              @Sturo UNBELIEVABLE !!!! Go for a new quality cable and problem solve, gotta say I love U Bro thank you so much
                                Sturo @Kecha
                                @Kecha Glad it worked out! Have fun!
