    Macintosh (Basilisk II) 8-bit Color
    basilisk iimacintosh8-bit color
    222 Posts 11 Posters 96.0k Views
      spud11 @hermit
      @hermit Thanks for the explanation.
      Unfortunately, no (at least from my point of view).
      The only way I found was to have a separate disk (hard drive) for each game. I only ended up doing the 2 games - Prince of Persia and Prince of Persia 2. These were the only games I really wanted and I wanted them to start automatically which they each do using shortcuts on the Mac.
      • H
        hoeveler @mediamogul
        @mediamogul I've been seeing this on the forum here about this mysterious basilisk config file that needs to be in basilisk but I haven't seen anything in the docs about this. Seems like the docs could use a lot more information about basilisk. Where can I find out how to create and use this config? I have my os 7.5.3 Macintosh img and rom working fine, all I'd like to do now is make it be 640x480 and full screen. If I do anything lower than 1600x1200 in the run command options or within the emulator using the screen settings, it displays in a smaller window in the upper left corner of the display.
