    Macintosh (Basilisk II) 8-bit Color
    basilisk iimacintosh8-bit color
    222 Posts 11 Posters 98.1k Views
      edmaul69 @Meneer Jansen
      @meneer-jansen @mediamogul woohoo!! I have it working every time. Just like @Meneer-Jansen i dont have the on-start and on-end settings. It locks my system up too. It works with displaycolordepth8 setting only.
      A NOTE TO NEW COMERS: do not add “displaycolordepth8” in basiliskii.cfg and enable dispmanx until/unless you change your color to 16 color b&w first or it is pre setup at 256 colors/16 color b&w.
        @edmaul69 said in Macintosh (Basilisk II) 8-bit Color:
        do not set add “displaycolordepth8” in basiliskii.cfg until/unless you change your color to 16 color b&w first or it is pre setup at 256 colors/16 color b&w.
        This was likely my problem when I first blacked out on startup. Now that it's set in the Mac environment I'll remove my own onstart/end to confirm.
          edmaul69
          one thing, my image made from minivmac which is b&w boots with/without sleep 2; but my 256 color image will not boot with it.
            @edmaul69
            That approach was a nonstarter anyway. It's useful to alleviate possible race conditions in a few cases, but ended up not applying here.
              edmaul69 @mediamogul
              @mediamogul i still cant get it to boot every time. the first time it worked 3 times in a row.then i tried with the on-start/on-end settings and they didnt work and now it wont boot every time for me.
                @edmaul69
                Mine's still launching every time so far, but I still feel like we're all going to be spinning our wheels on shaky ground without an upstream fix. The author of the displaycolordepth8 fix even said that his addition was a hack and almost didn't submit it officially.
                I'm not around my setup at the moment, but I'm curious to see what affect removing the onstart/end has for me. I'm betting that, as you say, having the Mac environment previously set to 256 will make all the difference. Did I understand you correctly in that you can potentially stave off a crash by first selecting 'Black & White' before switching to 256? If so, will this also work in reverse as an intermediate step between 256 and a higher setting?
                edmaul69E 3 Replies Last reply Reply Quote 0
                  @mediamogul i was mentioning it needing to be changed before enabling dispmanx. I might not have said that correctly.
                    @mediamogul edited the original post
                      @mediamogul @Meneer-Jansen can you post youremulators.cfg files?
                      mediamogulM Meneer JansenM 2 Replies Last reply Reply Quote 0
                        @edmaul69
                        Sure...
                        basilisk = "/opt/retropie/emulators/basilisk/bin/BasiliskII --rom /home/pi/RetroPie/roms/macintosh/mac.rom --disk /home/pi/RetroPie/roms/macintosh/disk.img --extfs /home/pi/RetroPie/roms/macintosh --config /opt/retropie/configs/macintosh/basiliskii.cfg"
                        default="basilisk"
                          @mediamogul i found my issue of it not booting every time. i had a typo in the basiliskii.cfg. i have the on start and on end set how @Meneer-Jansen posted it. it works all the time now. thank you both.
                            @edmaul69, @Meneer-Jansen
                            I just tested mine without the onstart/end scripts, and while it never crashed for me with them on, everything is running fine without them. @Meneer-Jansen, I think it's probably safe if you want to remove those particulars in your guide above for posterity. While still not a perfect solution, I'm satisfied with what we now have as-is. If you guys ever experiment with streamlining the process, or learn anything new I'd always be interested to hear it.
                            Meneer JansenM 1 Reply Last reply Reply Quote 1
                              spud11
                              Hi. There was some reference to lxde earlier in this thread, but I'm assuming we don't need this - that we can just install BasiliskII following items 1 to 9 of Meneer Jansen's guide in this thread from a day ago (and pray it works!)
                              edmaul69E Meneer JansenM 3 Replies Last reply Reply Quote 0
                                edmaul69 @spud11
                                @spud11 yes just use his latest guide except ignore the runcommand stuff. If the img file isnt already in 16 color b&w or 256 color, do not add the “displaycolordepth 8” to the basiliskii.cfg or set the dispmanx to “enabled” in retropie-setup.
                                  edmaul69 @spud11
                                  @spud11 so if it isnt in 256 color, set it to 16 color b&w. Then add the other stuff in the guide above. After that boot the img thats set to b&w then change to 256 colors. You cant set it to 256 colors when it is in thousands or millions of colors. It crashes the program if you do.
                                  S Meneer JansenM 2 Replies Last reply Reply Quote 0
                                    spud11 @edmaul69
                                    @edmaul69 Okay, thanks so much for your help on this. I'll have a crack at it this evening after work and let you know. I haven't played around with BasiliskII on Linux or Retropie yet, but have on Windoze and, sadly, it hasn't been a happy experience so far.
                                    • Meneer JansenM
                                      Meneer Jansen @edmaul69
                                      @mediamogul @Meneer-Jansen can you post your emulators.cfg files?
                                      basilisk = "/opt/retropie/emulators/basilisk/bin/BasiliskII --rom /home/pi/RetroPie/roms/macintosh/mac.rom --disk /home/pi/RetroPie/roms/macintosh/disk.img --disk /home/pi/RetroPie/roms/macintosh/disk02.img --extfs /home/pi/RetroPie/roms/macintosh --config /opt/retropie/configs/macintosh/basiliskii.cfg"
                                      default = "basilisk"
                                      Avid Linux user.
                                      • Meneer JansenM
                                        Meneer Jansen @mediamogul
                                        @mediamogul said in Macintosh (Basilisk II) 8-bit Color:
                                        Did that, see: https://retropie.org.uk/forum/topic/1049/macintosh-basilisk-ii-8-bit-color/137 (i.e. post No. 137 in this here topic). :-)
                                        Avid Linux user.
                                        • Meneer JansenM
                                          Meneer Jansen @spud11
                                          @spud11 said in Macintosh (Basilisk II) 8-bit Color:
                                          You're right: I do not need LXDE anymore. The procedure from a day ago that you referred too is in post 137 here.
                                          Avid Linux user.
                                          • Meneer JansenM
                                            What exactly do you mean? Must one set BII to "16 gray shades, B&W" before activating dispmanx and setting the "displaycolordepth 8" option in /opt/retropie/configs/macintosh/basiliskii.cfg? So do you mean that the correct procedure must be:
                                            1. Start BasiliskII and set the color mode to 16 gray shades by clicking on the Apple logo at the upper left hand side and choosing:
                                              Control panels --> Monitors --> tick "Gays" and "16".
                                            2. Activate dispmanx for BII and set displaycolordepth 8 in BII's config file.
                                            Does BII crash if you don't do it this way?
                                            P.S. Proof reading of the procedure in post 137 is needed.
                                            Avid Linux user.
