    Issues with sega genesis hub
    genesis hubpowerxbox 360
    13 Posts 3 Posters 3.4k Views
    • lostlessL
      lostless
      Anybody have issues with the sega genesis hub? I'm having an issue where the Xbox 360 wireless adaptor is failing to work when other things are plugged into the hub. But sometimes it works???? Any ideas? Im assuming its power management that the hub can't handle a whole lot.
      • lostlessL
        lostless
        after doing some testing, it takes about 30 seconds for the hub to fully turn on the xbox 360 wireless adaptor, with or without nothing else plugged in. The adaptor turns on and off until the light fully turns green. It is the hub, because i plugged it directly to the pi and it turns right on. Maybe ill just cut the wires or one the plots and wire it directly to the pi.
        • lostlessL
          lostless
          even more testing. even though my controllers are connected, sometimes, they just don't respond. Its not a power issue, at least it doesn't seem so, because I plugged a powered hub into the other hub and had the same issue. At that point it should be data only going to the hub and then the pi.
            edmaul69 @lostless
            @lostless are you using the xboxdvr or xpad? I believe you should be using xpad.
            • lostlessL
              lostless @edmaul69
              @edmaul69 I'm using xpad. The receiver has no issues when plugged directly into the pi. I think i'm just going to take one port and make it plug directly to the pi.
              • spruce_m00seS
                spruce_m00se
                i have an issue with a different hub. Some things work, some dont, some did and now dont.
                I have been told on the raspberry pi forums that the zero has issues with many hubs.
                funnily enough my rogue hub wont work with a keyboard, but will with wifi and the ds4 receiver usb dongle.
                • lostlessL
                  lostless
                  well i solved my issue. desoldered one port and soldered it directly to a port on the pi. No problems now. and I also have a full powered port now as well. showing a pic of the final incase some one else runs into this.
                    edmaul69 @lostless
                    @lostless you could have just wired the hubs power to the switch like your pi and saved yourself all the hassle.
                    • lostlessL
                      lostless @edmaul69
                      @edmaul69 I thought about that, but xbox 360 adaptor still had issues on a powered hub going through the sega hub. At that point the adaptor did not get its power from the hub. So i don't think it was a power issue. Too late to go back and test. Im done with this project. :D
                        edmaul69 @lostless
                        @lostless for a friends pi, i shortened the microsoft adapters cable to about 3 inches. I have replacement usb tips so i just put a new one on the end of the shortened cable. I think the length of the cable is a big problem when it comes to the issue you are having as it is stupid long and i think the hub just doesnt have enough power to push it.
                        • spruce_m00seS
                          spruce_m00se
                          something looks wrong there to me, it looks like the red wire has a pcb trace conencting it to the case solder point of the usb connetor.
                          if I were you i would do a continuity check to make sure that isnt causing any potential issues, also the 5v rail of the now "powered" usb port, should be cut on the pcb to avoid any potential backfeed into the 5v line that was previously powering it.
                          • lostlessL
                            lostless @spruce_m00se
                            @spruce_m00se the pic shows depth quite poorly. The leads from the USB port are desoldered from the hubs pcb. It is not connected to the hub anymore.
                            spruce_m00seS 1 Reply Last reply Reply Quote 0
                            • spruce_m00seS
                              spruce_m00se @lostless
                              @lostless aha, ok then.
