Issues with PS1 controller via GPIO
I'm having issues with my PS1 controller. It gets detected, however it only responds to key presses whenever it feels like. It's absolutely random. And when it does, it has a (variable) delay. I've had it working before, did the exact same thing now, but I really can't get it working again. Did everything as usual, installed gamecon drivers, connected the remote (verified the connections), but it's still unreliable. Tried both on my Pi 0 and Pi 1 B, with the same SD card, same behavior on both.
Pi Model: Pi 0 (same thing on my Pi 1 B)
Power Supply used: Same thing with 2A PSU and connected to my router's USB port.
RetroPie Version Used: Tried with an old RetroPie image I had (not sure which version) and with 4.2 downloaded a few hours ago.
Built From: RetroPie images straight from the website.
USB Devices connected: keyboard
Controller used: non-analog PS1 controller (SCPH-1080)
Error messages received: None
Log found in /dev/shm/runcommand.log (if relevant): Not sure if this is relevant? Module runs successfully (ran tail /var/log/kern.log to check) and the controller is detected when setting up inputs on emulationstation
Guide used: Well... My head and this: http://piplay.org/forum/discussion/1354/install-gamecon_gpio_rpi-without-using-retropie/p1 which was the only really helpful thing I found a year ago when I first tried to make this workI tried on both Pi's with power from both the 2A PSU and router usb port. I checked wiring 2/3 times. I've tried with an analog PS2 controller, same thing happens. I'm not sure what else to do. Thanks in advance for any help.
