    Pause when controller disconnects
    controllerretroarch
    13 Posts 4 Posters 1.9k Views
    • SanoS
      Sano
      I just lost at puyo puyo because my PS3 controller ran out of battery. How frustrating !
      On the PS3/4, when the controller runs out of battery, the game automatically pause.
      Do you know if there is a retroarch option to emulate this (pause the game if a controller is disconnected) ?
      I looked in global and core option but found nothing.
      • SanoS
        Sano
        Hi Guys, I didn't had any answer so maybe I'm the only one that have this issue.
        I searched though retroach options without finding anything like "pause when a controller disconnects".
        Nevertheless, after finding an UDEV solution for switching to TV when a controller is connected, I just realized that a similar rule when a controller is disconnected could pause the current game.
        The problem is I didn't find any way to either :
        • send a keystoke to retroarch current process (It doesn't accept standard input through /proc/"pid"/fd/0)
        • or command current retroach thrugh CLI
        So basically I'm stuck :)
        Does anyone has an idea ? Could named pipes work ? (It would require a change in retroarch launch script)
        The last resort would be to open a feature request on retroarch...
        • SanoS
          Sano
          Digging up this thread after 6 months and no answer :)
          After finding the feature described here https://retropie.org.uk/forum/topic/15283/damn-great-retroarch-feature-i-totally-missed
          I enabled the Network Control Interface feature, and just created a new UDEV rule :
          ACTION=="remove", SUBSYSTEM=="input", ENV{DEVNAME}=="/dev/input/js*", RUN+="/bin/bash -c '/bin/echo -n MENU_TOGGLE | /bin/nc -u -w1 127.0.0.1 55355'"
          And it works : Retroarch menu pops up (and game pause) if a controller disconnects.
          I won't loose again because an out of battery DS3 :)
          My 2 cents.
          Edit : note you can also pause the game by replacing MENU_TOGGLE by PAUSE_TOGGLE, but it's the retroach (not the in-game) pause, so you have to use a keyboard or the network command again to resume the game, hence I preferred the menu solution.
          D 1 Reply Last reply Reply Quote 4
            Chuck_B
            @sano said in Pause when controller disconnects:
            My 2 cents.
            That's really interesting. Does it work with any kind of wireless controllers?
              mitu Global Moderator @Chuck_B
              @chuck_b said in Pause when controller disconnects:
              It should work with any type of controller, the configuration makes it so that when a gamepad is disconnected, the menu is shown in RA.
                dudumaroja @Sano
                where exacly you add this command?
                  mitu Global Moderator @dudumaroja
                  @dudumaroja Create a new file called /etc/udev/rules.d/01-rp-disconnect.rules and add the text in that file. Reboot and it should take effect.
                    dudumaroja
                    this work amazingly well.. this should be included with retropie.
                      Chuck_B @mitu
                      @mitu naming that file 01-rp-disconnect.rules is mandatory?
                        @chuck_b No, just the file extension has to be .rules , otherwise you can name it any way you want
                        From https://wiki.debian.org/udev:
                        [...] Files in there are parsed in alpha order, as long as the name ends with ".rules".
                          Chuck_B @mitu
                          @mitu I put the extension ".rules", but when i disconnect the controller the game doesn't pause.
                          I setted network_cmd_enable = "true" on retroarch.cfg
                            Which config file ? This should be done in the global (/opt/retropie/configs/all/retroarch.cfg) file. Did you restart your system after adding the .rules file ? What controller are you using ?
                              Chuck_B
                              i solved. I forgot to remove the # before network_cmd_enable = "true" :)
