    Create a custom ES system able to launch games for many systems
    emulationstatiocustomisationscustom theme
    157 Posts 15 Posters 76.2k Views
    • TMNTturtlguyT
      TMNTturtlguy @hansolo77
      @hansolo77 why did you have to rescrape? Just because you moved the roms to a different folder? You could just use notepad++ and do a replace all to all the files in the folder. Takes about 10 seconds.
      • hansolo77H
        hansolo77
        There's more to it than that though. All my achievement artwork was saved with the folder name as part of the filename. So they all looked like _ACHIEVEMENTS_Sonic 1 (etc).mp4. It's all good. I'm in the process of making the symlinks now. Fingers crossed!
        I also create a system logo for Achievements. I was going to upload it the ComicBook theme page, but everything says the file is corrupted or something. I even tried to copy it back over from the Pi and still no good. If it's corrupted, it shouldn't work with the Pi either right? I dunno. It works, that's all that matters.
        Who's Scruffy Looking?
        • hansolo77H
          hansolo77
          I think I got it working! Took forever adding the last couple of systems, probably due to memory or something. All told, I now have a custom system named "Achievements", and there are currently 1426 games to choose from! :) I need to do some further checking and testing, but so far all the games look like they have proper metadata installed.
          Next on my list - figure out how to get the ComicBook loading screens to install.
          Thanks @meleu !!!
            meleu @hansolo77
            @hansolo77 said in Create a custom ES system able to launch games for many systems:
            Didn't rpie-art work for you?
            • hansolo77H
              hansolo77
              I never progressed any further with it because I can't get it to load up in the Retropie menu. I'm tackling this today.
              • namyzarkN
                namyzark @meleu
                @meleu said in Create a custom ES system able to launch games for many systems:
                https://retropie.org.uk/forum/topic/11499/change-es_systems-cfg-script
                Wonderful! I have combined @TMNTturtlguy 's change ES system script with @meleu 's 'Custom ES System able to launch games for many systems. I have a very happy family right now.
                Next: to see if I can combine symbolic links with actual games files so that multiple people in my house can play the same game without overwriting each others save games/save states.
                  pjft
                  Hi all,
                  The ability to create custom collections (effectively, custom systems) from within ES is now available.
                  Best.
                  • TMNTturtlguyT
                    TMNTturtlguy @meleu
                    @tmntturtlguy said in Create a custom ES system able to launch games for many systems:
                    @meleu Is there anyway that we can point the custom folders with the symlinks to use a custom launching image?
                    We can think in a workaround for it, but currently not.
                    Maybe it's better to use the game specific launching image feature.
                    More info in the docs: https://retropie.org.uk/docs/Runcommand/#adding-custom-launching-images
                    So I know most users are now using the neat and easy custom collections in ES, but for anyone still using this symlink method, i have figured out how to do what I had originally asked in an early post, quoted above. Now when I launch a rom from my TMNT collection my TMNT launch screen appears based on the theme. When I launch a Mega Man game from my Mega Man collection, a Mega Man launch screen appears. If i launch the same game from the NES system, the NES launch screen appears! Here is how to do it, if anyone is interested:
                    • Go to /opt/retropie/configs/all/emulationstation
                      • Create a folder called “Launching”
                        • Place folders for each system within this folder, with the launching image inside that folder
                        • Example, place TMNT folder here with “Launching.png”
                    • Create a folder called “runcommand”
                      • Place a custom runcommand.sh file for each custom system here named with the custom system at the end:
                        • Example: runcommonandtmnt.sh
                      • Edit runcommand starting at line 915
                    • # look for custom launching images
                       if [[ "$IS_SYS" -eq 1 ]]; then
                      images+=(
                      "$HOME/.emulationstation/Launching/TMNT/launching"
                      Fi
                    • Go to /home/pi/bin/
                      • Add custom runcommand for each system
                        • Example: runcustomtmnt.sh
                      • Edit the last line to launch the custom runcommand from above
                        • Example:
                          - /opt/retropie/configs/all/emulationstation/runcommand/runcommandtmnt.sh 0 _SYS_ "$system" "$rom"
                    • In putty, go to both new runcommand files and type the following:
                      • chmod +x nameofruncommand.sh
                    • Go to your es_systems.cfg
                      • Modify your runcommand for each system to the new runcustom.sh you created. Example: runcustomtmnt.sh
                    So anyone crazy enough to have read through this without just leaving the post might want to know why I am still running the custom systems through the script and not using the newest updates to ES. There are a few reasons:
                    1. I already went through all the work to set these up about 2 months prior to this being available in ES.
                    2. Using this symlink script I am able to have a gamelist for each custom system. I can then modify my images and marquees to be different than in the standard system list.
                    3. I now have the ability to have the custom launching images for each custom system.
                    4. Bottom line, it is a lot more work for the same results, but I have a lot more flexibility to set them up exactly how I want them.
                      cyperghost @TMNTturtlguy
                      @tmntturtlguy That's very complicate! And we have the ES collections as @pjft mentioned. But of course that scripting provides much more flexibility ... You are so a kind of person... here we go!
                      You forget... there are other "entrypoints" as only the runcommand.sh as it's the "brain" of our RetroPie I would leave it untouched.
                      I would do following:
                      You have already a bash-file that provides $rom (that's the runcustom.sh)
                      So you can identify the system by filepath...
                      1. Best method is to compare es_system.cfg rom filepathes with extraced one = 100% working methof
                      2. Set the filepathes on your own script so /home/pi/roms/nes could be NES system
                      Next step...
                      As an example...
                      You identified it as SNES system
                      Then you extract the original launch-image for SNES system and temporarily move it somewhere and copy launch image of a custom system...
                      To genereate a generel script you can use command line parametes like -megaman or -tmnt ....
                      So for your MEGANMAN "system" in es_systems.cfg you set
                      <command>/home/pi/bin/runcustom.sh %ROM% -megaman</command>
                      and then create "usecases" for the parameters "-megaman" "-tmnt" "-mario".... within @meleu runcustom.sh script!
                      Last line reverts all back to normal!
                      • TMNTturtlguyT
                        TMNTturtlguy @cyperghost
                        @cyperghost Thanks as always for your kind and quick response to help me out!
                        I have a few questions for you as I am not fully understanding your instructions:
                        1. In regards to the runcomand.sh file - Yes i understand it is the brain of running the roms. I have left the runcommand.sh in its original location and it is untouched. It still runs all the roms for the normal systems. The modified runcommands are moved to the .emulationstation folder, thus they will not be orverwritten, and I can simply delete them change my es_systems.cfg back to the original path for my custom systems. In theory, if anything does not function properly, I can simply revert back with no harm done. Do you see any issues with this thinking?
                        2. I have my full system setup, and don't plan to change how anything is executed outside of the retroarch files themselves. I have only modified the location in which the runcommand pulls the launch image. What if any are the downsides of doing this? All other runcommand functions are untouched and as it is the "brain" it should not see or execute any differently than the standard runcommand.
                        Now onto your solution, I think this might be more elegant than my attempt, however I am unclear on how it works.
                        • what are you stating here? I don' t follow. are you moving the roms location? if i repath the roms folder, then i would no longer be launching the same rom from the original location, which defeats the purpose of @meleu's script. Please explain more if you have the time.
                        • what do you mean here? Currently @meleu's runcustom.sh script tells to launch using the original runcommand for the rom in its original system folder. That is the end of the runcustom.sh and it turns everything over to the runcommand.sh file. How would I create a last line to set all back to normal in the runcustom.sh script?
                        Again, thank you for all of your help!
                          @TMNTturtlguy @cyperghost hello fellows!
                          IMHO you guys are going through a very complex/confusing way. I already have thought on a simpler solution for this, just give me a couple of days to implement and test, and then I'll let you know when it's ready. ;-)
                            @tmntturtlguy Yes... sometimes I have two or three ideas together and it's a bit diffucult to explain.
                            So next attempt!
                            My idea is following. The launch images are fixed for each system. So a SNES ROM launches a SNES images. But it's your turn to decide what is the content of the picture ;)
                            What I mean with this?
                            The runcostum script extracts ROM name and ROM system (Good work @meleu)
                            But I'm not sure if ROM $system equals all usecases.
                            For NES and SNES it may work ;) but to cover all usecases it would use the ROMs folder and compare location string with es_systems.cfg >> 100% working solution.
                            But the $system should also work
                            Then you add following to runcostum.sh
                            As I don't know the location of the custom-launch-images I use just the name megaman.jpg
                            # Set custom lauching image
                            mv "/opt/retropie/configs/$system/launching.jpg" "/opt/retropie/configs/$system/launching.jpg.org"
                            cp megman.jpg  "/opt/retropie/configs/$system/launching.jpg"
                            # Start  runcommand
                            /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ "$system" "$rom"
                            # Revert back
                            rm "/opt/retropie/configs/$system/launching.jpg"
                            mv "/opt/retropie/configs/$system/launching.jpg.org" "/opt/retropie/configs/$system/launching.jpg"
                            With the parameter you can avoid to use megaman.jpg as hard coeded rather set general usecases ;)
                              cyperghost @meleu
                              @meleu Is this a solution I posted above is in your mind?
                              Hello my friend ;)
                                meleu @cyperghost
                                @cyperghost To be honest I'm against this solution. If for some reason the user turns off the pi while emulator is running, it will mess his/her launching images configs and will lead to confusion.
                                Wait a little, it should be a way simpler than those workaround solutions... :-)
                                  cyperghost @meleu
                                  @meleu Well .... yes ;) But it is simplier as @TMNTturtlguy solution to need one runcommand for just one system - as it uses a script that is already provided and has nothing to do with the original RetroPie config.
                                  Again I will learn something new soon. Excite me ;)
                                  • TMNTturtlguyT
                                    @cyperghost @meleu thank you both for your time and efforts!
                                    @meleu as is the usual case, you always have a much more elegant way of making my complex and messy round about ways of doing things work much better.
                                    To both of you, you are both very kind, but I am not sure how many people out there this will help, I do appreciate your efforts, but please do not spend to much of your personal time working on something that might not benefit many people.
                                    Thanks!
                                    meleuM cyperghostC 2 Replies Last reply Reply Quote 0
                                      meleu @TMNTturtlguy
                                      haha! I hope it will be a very simple solution. You will not owe me anything because of it. :D
                                        @tmntturtlguy The reason is, that I'll learn some tricks how to solve such usecases. It won't be a big thing to do but it's just a quesion of how elegant it can be done.
                                        I think @meleu will also present a general solution that uses annother parameter to get use of several launching images.
                                        • TMNTturtlguyT
                                          TMNTturtlguy
                                          Just to show anyone who is interested how this setup works, here is a video. Notice that in the Nintendo system, the marquee above the video the teenage mutant ninja turtles game logo, in the TMNT custom system, the marquee shows what system the game is from. Also note, i have edited the game names in the games list as well.
                                            @cyperghost @TMNTturtlguy the simple solution I've found depends on the approval of this Pull Request with a little change in runcommand.sh (added two lines). Jools is not (yet) convinced that this usecase is worth it. If you guys have more arguments, try to comment something there.
