    output problem
    helpsetup
    5 Posts 4 Posters 1.2k Views
      shingouki
      I have installed retropie onto the PI3 model B, but the output on my pioneer plasma is
      link
      anyone has any idea how this can be fixed?
      below is the /boot/config.txt
      # http://rpf.io/configtxtreadme
      #hdmi_safe=1
      #disable_overscan=1
      #overscan_left=16
      #overscan_right=16
      #overscan_top=16
      #overscan_bottom=16
      # overscan.
      #framebuffer_width=1280
      #framebuffer_height=720
      hdmi_edid_file=1
      hdmi_force_hotplug=1
      hdmi_group=1
      hdmi_mode=31
      #hdmi_drive=2
      # no display
      config_hdmi_boost=7
      # uncomment for composite PAL
      #sdtv_mode=2
      #arm_freq=800
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      # Uncomment this to enable the lirc-rpi module
      #dtoverlay=lirc-rpi
      dtparam=audio=on
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=256
      overscan_scale=1
      AlexMurphyA edmaul69E 2 Replies Last reply Reply Quote 0
      • AlexMurphyA
        AlexMurphy Banned @shingouki
        @shingouki What is the resolution of your TV?
        Did you create an edid.dat file for some reason? Was the Pi not seeing the television?
        Why have you got this set to 1080p @ 50Hz? Most TVs would be hdmi_mode=16 ie 1080p @ 60Hz.
        Have a read through this regarding EDID and hdmi_mode https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
          dankcushions Global Moderator
          i think this sort of picture can happen if you have a bad HDMI cable. have you any others you can test with?
            shingouki @dankcushions
            @dankcushions said in output problem:
            Looks like this is the cause, changed the cable and now it is fine. Thanks for yout help..
              edmaul69 @shingouki
              @shingouki i cant find anything on the web about hdmi_edid_file=1. Can you tell me what it is used for?
