    Retropie-kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2)
    retropie 4.2kernel panicmicro sd
    24 Posts 9 Posters 18.1k Views
    • mr315M
      mr315 @jonnykesh
      @jonnykesh Bought on the internet.
      I bought another one now, and it worked fine. SanDisk Ultra 64gb. Thanks for all.
      • jonnykeshJ
        jonnykesh @mr315
        @mr315 I use Amazon or an actual physical shop when buying larger SD cards. At least then you have some comeback and a 1 year warranty.
          Seedname101
          I have a similar problem.
          Raspberry Pi 2 b
          San Disk Ultra 32GB
          RetroPie 4.4.4
          Using Balena Etcher on mac (flashed through retropie4.4.4.img...)
          A couple of usb drives (not used all at the same time) , a keyboard, wireless usb controllers, wifi dongle.
          Generic xbox controllers (xpad driver)
          Error messages received: kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2)
          Emulator: ES/Retropie
          Turning the retropie on.
          The only thing that makes this different is that I have a pretty good idea on how this happened. I was using a usb- micro sdhc adapter drive to transfer (4876) games at once. Also, I overclocked my retropie around lunch. These two factors MOST LIKELY caused this to happen and I want to keep my games... since I have over 10,000, So re writing it or formatting it isn't an option. Also, my usb keyboard wont work because of the error. All of my usb ports are useless. I wouldnt only like my games though. I did a ton of programming on it and have TONS of stuff like background music, custom loading screens, game launch screens, etc., I also wonder if there is a file on the sd card that has all of that on it, so I can just use a new image and take that. Thanks in advance!
            BuZz administrators @Seedname101
            @Seedname101 please follow the guidelines agreed when signing up. This thread is from 2017. Please create a new topic.
