    Daphne - Dragon's Lair problems
    daphnedragons lair
    7 Posts 3 Posters 4.8k Views
      spud11
      Pi Model or other hardware: See signature
      Power Supply used: standard + 2 powered hubs
      RetroPie Version Used: See signature
      USB Devices connected: See Signature
      Controller used: See Signature
      Error messages received: As per log shown below
      Guide used: Both Retropie docs and https://gameroomsolutions.com/setup-daphne-raspberry-pi-3-retropie/#comment-9764
      File:
      Emulator: Daphne
      Attachment of config files:
      How to replicate the problem: Start the game and it simply runs through the death animations. The log seems to bear this out.
      I've followed all of the instructions to the letter (so far as I can tell). I've tested on 2 separate Pi3's - one about 6 months ago and one tonight, with the same outcome. I've installed Daphne on my PC and using the Dragon's Lair DVD-Video 20th Anniversary edition DVD have set it up to work on PC. Seems to work well. I've transferred all relevant files onto the Pi into the correct folders and created the lair.commands file. However, despite installing it twice, I'm still getting the same outcome - start the game (press 1 and 5) and then Dragon's Lair starts but all that happens is that the death animations run through.
      daphne_log.txt appears below.
      --DAPHNE version 1.0.13
      --Command line is: /opt/retropie/emulators/daphne/daphne.bin lair vldp -nohwaccel -framefile /home/pi/RetroPie/roms/daphne/lair.daphne/lair.txt -homedir /opt/retropie/emulators/daphne -fullscreen -nocrc -noissues -noserversend -latency 950 -x 640 -y 480 -bank 1 00110111 -bank 0 10011000
      --CPU : UnknownCPU 0 MHz || Mem : 0 megs
      --OS : Linux 4.9 || Video : Unknown video
      --OpenGL: Compiled In
      --RGB2YUV Function: C
      --Line Blending Function: C
      --Audio Mixing Function: C
      Setting alternate home dir:
      Disabling ROM CRC check...
      Setting Search Latency to 950 milliseconds
      Setting screen width to 640
      Setting screen height to 480
      Set 640x480 at 32 bpp with flags: 20
      Initializing sound system ...
      GI Sound chip initialized at 2000000 Hz
      Joystick #0 was successfully opened
      Remapping input ...
      Loading compressed ROM image dl_f2_u1.bin...8192 bytes read.
      Loading compressed ROM image dl_f2_u2.bin...8192 bytes read.
      Loading compressed ROM image dl_f2_u3.bin...8192 bytes read.
      Loading compressed ROM image dl_f2_u4.bin...8192 bytes read.
      Framefile parse succeeded. Video/Audio directory is: /home/pi/RetroPie/roms/daphne/lair.daphne/
      YUV overlay is done in software (ie unaccelerated).
      Booting ROM ...
      Play
      LDP : disc is already playing, play command ignored
      Play
      Display disable received
      Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode
      WARNING : search latency needs to be redesigned, it is currently disabled
      search succeeded d0
      Play
      Search to 306 received - [25] Attract Mode, Sequence 0 Attract Mode
      search succeeded d0
      Search to 1424 received - [ 0] Introduction, Sequence 0
      search succeeded d0
      Play
      Search to 1823 received - [ 0] Introduction, Sequence 3
      search succeeded d0
      Play
      Search to 12725 received - [11] Flaming Ropes (Mirrored), Sequence 0
      search succeeded d0
      Play
      Search to 13127 received - [11] Flaming Ropes (Mirrored), Sequence 9 Death Scene
      search succeeded d0
      Play
      Search to 9965 received - [ d] Flying Horse Barding, Sequence 1 Resurrection Scene
      search succeeded d0
      Play
      Search to 10021 received - [ d] Flying Horse Barding, Sequence 2
      search succeeded d0
      Play
      Search to 10453 received - [ d] Flying Horse Barding, Sequence 9 Death Scene
      search succeeded d0
      Play
      Search to 22682 received - [1f] Underground River, Sequence 1 Resurrection Scene
      search succeeded d0
      Play
      Freeing memory used to store audio stream...
      Shutting down sound system...
      Shutting down video display...
      Any suggestions would be welcome. Thanks.
      • caver01C
        caver01 @spud11
        @spud11 Am I reading the log correctly that your ROM is the F2 version? I think you should check your lair.commands file and carefully look over your DIP switch settings. It looks like you have bank 0 (A) switch 3 and 7 set to "0" (OFF). If you are using the F2 ROM, that will put the game into engineer's diagnostic mode. See here.
        Each rom leverages the DIP switches differently, so you cannot use the same strings of ones and zeros for the DIP switch banks interchangeably. You really need to read what they do for the ROM version you are using. I suggest renaming your lair.commands file (or delete it) and trying with all defaults (no commands file) and see if you have a playable game. Then add back your command changes one at a time, being most careful about the DIP settings.
          spud11 @caver01
          @caver01 Thanks!
          Setting up Daphne is a bit more complicated than I thought. I'm sure that it is revision F2 of the roms.
          I've now had a better look at the documentation surrounding Daphne and Dragon's Lair and have also found this thread: 'https://retropie.org.uk/forum/topic/2403/dragon-s-lair-lives-change-question/2'
          I deleted the lair.commands file. That didn't seem to change anything. I then changed the lair.commands file to below based on the thread referenced above but with no real change as, again, it just seems to run through the death animations. I've now got bank 0 switch A3 (the 4th switch in the sequence) set to on and switch A7 (the 8th switch in the sequence) set to on:
          -bank 0 11111101 -bank 1 01110010 -blank_searches -latency 950 -noserversend -x 640 -y 480
          For completeness, my lair.txt is as follows:
          151	lair.m2v
          The new log is as follows:
          --Command line is: /opt/retropie/emulators/daphne/daphne.bin lair vldp -nohwaccel -framefile /home/pi/RetroPie/roms/daphne/lair.daphne/lair.txt -homedir /opt/retropie/emulators/daphne -fullscreen -bank 0 11111101 -bank 1 01110010 -blank_searches -latency 950 -noserversend -x 640 -y 480
          Remapping input ...
          Framefile parse succeeded. Video/Audio directory is: /home/pi/RetroPie/roms/daphne/lair.daphne/./
          Booting ROM ...
          Play
          Play
          search succeeded d0
          Play
          search succeeded d0
          LDP NOTE: ignoring seek because we're already on that frame
          search succeeded d0
          search succeeded d0
          Play
          search succeeded d0
          Play
          Search to 9181 received - [ b] Closing Wall, Sequence 0
          search succeeded d0
          Play
          Search to 9301 received - [ b] Closing Wall, Sequence 4 Death Scene
          search succeeded d0
          Play
          search succeeded d0
          Play
          search succeeded d0
          Play
          search succeeded d0
          Play
          search succeeded d0
          Play
          Search to 22738 received - [1f] Underground River, Sequence 2
          search succeeded d0
          Play
            dizmodawg
            Go to YouTube and search Daphne setup on the Raspberry pi and there is a good tutorial that's what I used.
              spud11 @dizmodawg
              @dizmodawg I'm assuming you mean ETAPRIME's video. If so, I have now watched it and it was helpful, thanks.
              I'd set everything up correctly but having watched the back half of the video where ETAPRIME actually played the game, I realised that I was just soft - that the game wasn't running through the death animations as I thought, but that in fact I was actually playing the game without realising it, and that I was just totally and utterly rubbish at it and dying every single time.
              I think I might just put this game to one side for the time being.....
              caver01C D 2 Replies Last reply Reply Quote 0
              • caver01C
                caver01 @spud11
                @spud11 said in Daphne - Dragon's Lair problems:
                This should help.
                  dizmodawg @spud11
                  @spud11
                  Yes that is correct eta prime.
