    Pre selected System after RetroPie is loaded?
    retropienewbie
    3 Posts 2 Posters 652 Views
      atb1983
      Hi, I was wondering if there is a way to pre select a system in RetroPie after RetroPie is loaded.
      I couldn't find the option. I hope it makes sense.
      Thank you
        edmaul69 @atb1983
        @atb1983 i dont know the info to your question, but if you copy your es_systems.cfg from /etc/emulationstation/ to /opt/retropie/configs/all/emulationstation/ you can edit that file to put the systems in any order you want. That way the system you want will be the first you see. I also make the retropie menu the last system so i can access it easy. However, if you do that, if you add a new system to the pi, you need to open the file in /etc/emulationstation/ and copy that new systems info into the new locations file.
          atb1983 @edmaul69
          @edmaul69 Thanks for your help, I will give it a try :)
