    Is it okay for me to reboot system during update if my mirror is down?
    mirrorupdate
    3 Posts 2 Posters 1.0k Views
    • RedBatmanR
      RedBatman
      Okay so I was trying to update but it was just stalling so I went to my mirrors website https://mirror.umd.edu/ and well I put it on http://www.isitdownrightnow.com/ and it was giving the 404 error. So i had to reboot my system since it was taking a long time. Thing is do I have to worry about data corruption now?
      • TMNTturtlguyT
        TMNTturtlguy @RedBatman
        @RedBatman probably not, but you won't know until you try to restart, so just boot up and see.
        RedBatmanR 1 Reply Last reply Reply Quote 0
        • RedBatmanR
          RedBatman @TMNTturtlguy
          @TMNTturtlguy Well thankfully it was okay, my only irrational is that the mirror I use does go down sometimes, anyway I can check my mirror status or change my mirror in ssh?
