start up resalution? sides or buttom and top getting cut off and no 4:3 low res
- I can't change anything in config.txt file. It gives me a error that I don't have permission. I want to change the resolution to 780p. Shouldn't there be a way to just do it in the menu's somewhere.
- I brought my pie to my friends house with a crappy tv that did not have just scan mode on 1080i. the 2 sides get cut off.
3.When i pick a lower resolution lower then 720p it's no longer 4:3 no matter what setting I set it to and sometimes there is a black bar on the left side of the screen. 720p and 1080p shows up 4:3 the rest show up 16:9 and if i connect it directly to the tv and set it to normal shows 4:3 but bottom and top get's cut off. I also have a crappy tv but seems to have more resolutions then my old Samsung.
Forcing the res to 4k works good. IDK if it effects the pi itself or it's up-scaling. For my pc it forces the res to 4k which some of the games i can't handle so i have to switch it off and my consoles it upscale to 4k if I have that mode selected. IDK I don't notice a dif in fps even for ps1 still 60.
@Deltax5 if you put your sd card into a pc you can exit the config.txt. Or set up a password for root and login as root instead of pi if you are using an ssh or ftp program.
@Deltax5 said in start up resalution? sides or buttom and top getting cut off and no 4:3 low res:
the pi can't output at 4k so it would just be your TV upscaling the pi at 1080p. that's fine. the pi3 has a weak GPU but it can do an upscale to 1080p with no performance loss.
i'm assuming you're using a pi3 here.
I followed https://github.com/RetroPie/RetroPie-Setup/wiki/FAQ#why-cant-i-ssh-as-root-anymore
to change the root password. But when i enter sudo passwd root it comes up to change the password but I can't type anything at all. Just enter works then gives me a error? im doing this throu the pi. cuz when i try doing it thou WinSCP I get some sort of buffer problem and googled it but I got no idea where the advance options are to turn buffer off. and the command gives me the same error. -
to change the root password. But when i enter sudo passwd root it comes up to change the password but I can't type anything at all. Just enter works then gives me a error?the password is invisible as you type it. it won't appear on the screen.
yay i did it but i still want to know about that buffer problem
