    Netgear USB Wifi Dongle Detecting and powered by Rpi Zero, refuses to connect
    wifi problemwifims doscant connectraspberry pi 0
    1 Posts 1 Posters 887 Views
    • H
      hunters11
      Hello this is my first post on the forum, i have read the rules and the !! READ THIS FIRST !! post. The problem is, i want to play MS-DOS games but i need internet to download the required packages for Dosbox. Since i have the Zero i cant use ethernet (dont have a usb-ethernet adapter).I tried to use a Netgear A6210 Wifi Usb stick but it refuses to connect. When i use lsusb, the system detects the wifi stick as just "netgear". I have tried everything, including everything from https://retropie.org.uk/docs/.
      Relevant Information
      Pi Model: Raspberry pi zer0 1.3 camera ready
      Power Supply: Apple 5W power brick
      Retropie Version: 4.2
      built from pre-made SD card image - name: retropie-4.2-rpi1_zero
      USB Devices Connected: Insignia 4 port usb hub(with Razer blackwidow and Neatgear netgear a6210 attached)
      Controller Used: none
      thank you in advanced
