    FBA 2012 Controller Mapping Player 1 and 2 controlled by 1st player controller
    fba2x.cfgfbacontrols
    13 Posts 4 Posters 3.9k Views
    • TMNTturtlguyT
      TMNTturtlguy
      Running PI 3 updated to current builds
      controller - 4 payer arcade setup using dragonrise usb encoders
      Issue - fba 2012 emulator only
      In my arcade cabinet I am running just about every emulator you can name. I have my 4 controllers set up and they run perfectly for all emulators including mame, fba, neogeo, nes, snes, megadrive, etc. The only emulator I cannot get to work is fba 2012.
      Issue: When i press any button using player one, it does the same action for player 2. If i hit coin, both player 1 and player 2 get coins. I select a player, punch, jump, i am controlling both player. When i use player 2 controls it controls player 3.
      I have tried to set the controls in retroarch and it doesn't do anything. I try to bind the controls in retroarch and it only allows me to bind player 1.
      I have looked at fba2x.cfg and it looks correct. Here is some of the code for each controller:
      [Joystick]
      # Get codes from "jstest /dev/input/js0"
      # from package "joystick"
      # Defaults to XBOX 360 Controller
      A_1=1
      B_1=0
      X_1=2
      #player 2 button configuration
      A_2=1
      B_2=0
      X_2=2
      Any thoughts would be awesome! thanks
      Edit: I just removed players 2-4 from fba2x.cfg and it didn't change anything. I don't think it has any effect on the controls? Edit #2. This is probably because fba2x.cfg is for pifiba, which I don it use! Lr-fba works perfectly, lr-fba 2012 does not, but they should both use the retroarch.cfg???
        meleu @TMNTturtlguy
        @tmntturtlguy
        I'm afraid it's related with the joystick-selection tool somehow. Something like what @obsidianspider reported in this thread.
        You're right, that file has nothing to do with fba 2012. To let us help you we need to take a look at these files:
        • /opt/retropie/configs/all/retroarch.cfg (be sure to mask your retroachievements account info, if you have one)
        • /opt/retropie/configs/fba/retroarch.cfg
        TMNTturtlguyT 2 Replies Last reply Reply Quote 1
        • TMNTturtlguyT
          TMNTturtlguy @meleu
          @meleu thanks, I will be back at my pi in an hour or so and get that info.
          • TMNTturtlguyT
            TMNTturtlguy @meleu
            @meleu
            here a is pastebin link to /opt/retropie/configs/all/retroarch.cfg: pastebin
            here is ~/fba/retroarch.cfg
            input_remapping_directory = "/opt/retropie/configs/fba/"
              meleu @TMNTturtlguy
              @tmntturtlguy
              # If desired, it is possible to override which joypads are being used for user 1 through 8.
              # First joypad available is 0.
              input_player1_joypad_index = "1"
              input_player2_joypad_index = "2"
              input_player3_joypad_index = "3"
              input_player4_joypad_index = "0"
              Not sure why this is happening only with fba2012. Maybe a bug with this core? I can't say with confidence...
              Can you launch some game with fba2012 with verbose mode enabled and then post the log?
              As a workaround, if you have access to the cables/connections my suggestion is to plug the joysticks in the same order as the player. I mean the joystick 0 as player1; joystick 1 as player2 and so on.
              • FlyingTomahawkF
                FlyingTomahawk
                Isn't this
                suppose to look like this?
                input_player1_joypad_index = "0"
                input_player2_joypad_index = "1"
                input_player3_joypad_index = "2"
                input_player4_joypad_index = "3"
                  edmaul69 @meleu
                  @TMNTturtlguy in your /all/retroarch.cfg why is this numbered wrong? @meleu posted this too?
                  • TMNTturtlguyT
                    TMNTturtlguy
                    @meleu this is setup because i am using your joystick selection tool. It works great on everything except fba2012. I tried your work around of switching the plugs before i even started my posts yesterday. Originally they were ordered 2, 1, 3, 0 so tried switching them up. The best i could come up with was this, having 0 as the 4th player. The issue is that the encoder for 4th player is always reading as the first to connect, regardless which port i plug into. In order to fix this, i would have to disconnect every button and joystick wire from the USB encoders and hook this encoder up to player 1, and then rotate all encoders over 1 controller. That is a lot of work now that the control panel is all hooked up and i have to be so careful that every button is wired the same to each encoder. Good news is that I had another thread regarding which romsets to use for cps1, 2, and 3 and got a good tip about romset FBA v0.2.97.39 and it appears that this works well with lr-fba, and that runs great with your joystick selector too. I have tested about 10 roms and they are running so I am going to spend some more time testing out the roms and hopefully just not use 2012. Thanks for the help, I will report back.
                    @FlyingTomahawk That is what it is supposed to look like if the controls are all recognized in the correct order. I am using a pihut 7port powered usb hub and 4 dragonrise usb encoders. No matter what port i plug the 4th joystick into, that usb encoder always reads as joypad 0. I was able to get the other sticks ordered correctly, but 4th player is always 0 - as i stated to @meleu above, it is a lot of effort to remove the encoders and rewire for just this one system. I have N64 and Dreamcast all working correctly, and those are typically the hardest to setup!
                    @edmaul69 again, see above - they are not numbered wrong. The joystick tool from @meleu is awesome and lets you set this up so you can order your controls globally or per system.
                      edmaul69 @TMNTturtlguy
                      @tmntturtlguy have you tried system specific joystick-selection? Set the fba ones in whatever order makes it work.
                      • TMNTturtlguyT
                        TMNTturtlguy @edmaul69
                        @edmaul69 yes, I tried that. The current setting work for lr-fba. No matter what joystick is set to player 1 it always also controls player 2 simultaneously. I even removed players 2,3, and 4 and player 1 still controls player 1 and 2.
                          @tmntturtlguy so just curious what games/ game companies have you tried?
                          • TMNTturtlguyT
                            @edmaul69 Not sure what your exact question is, but the only reason i was using fba-2012 was for capcom cps games. The cps2 and cps3 rom sets I had would only play on fba-2012. They worked fine on mysetup with 2 ps4 controllers, however when I put them onto my arcade cabinet with 4 players and needed to use the joystick selection tool to set my controls I had issues. I have now changed my roms to a different rom set and they all work in lr-fbalpha. Does that answer your question?
                              @tmntturtlguy yeah that answers it. I was just going to test if i had any issues with some of the same games just in case but you more than answered the question.
