    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 103.5k Views
      cyperghost @barrymossel
      @barrymossel
      You see PID Detector says an emulator is running with PID xxxx.
      What happens if you kill that PID with kill xxxx and can you also enter output of ps -a after the kill command?
      The script is v 1.56! So it's the newest version.
        barrymossel
        pi@retropie:~ $ kill 6901
        pi@retropie:~ $ ps -a
          PID TTY          TIME CMD
          992 tty1     00:00:00 bash
          997 tty1     00:00:00 bash
          998 tty1     00:00:00 emulationstatio
         1005 tty1     00:00:00 emulationstatio
         1008 tty1     00:01:54 emulationstatio
         6902 tty1     00:01:00 scummvm
        10250 pts/0    00:00:00 ps
        So ScummVM keeps running. I guess, as expected.
          @barrymossel That's interesting!
          That's because ScummVM creates itself a bash call.
            meleu @cyperghost
            @cyperghost said in Mausberry Shutdown Script Doesn't Save Metadata:
            I would change this sentence to: "That's because runcommand starts ScummVM through a bash call."
              cyperghost
              @meleu Ready for quick'n'dirty coding? :)
              what about a kill $(expr $emupid + "1")
              of course you check before if pid is active :)
                meleu @cyperghost
                @cyperghost that behavior reported by @barrymossel was the reason why I was killing the emulator with -9 (SIGKILL). When you kill a bash script with SIGKILL it kills all its child processes.
                But I realized that this isn't a good approach for retroarch, because it wouldn't save the .srm file...
                Looks like there are room for more improvements on that script. Will post something soon. (edit: or maybe you can do it yourself: just check if the first string on that 4th line is bash, if yes, kill the process with -9)
                  barrymossel
                  Ehm, I was wondering: does it even matter that ScummVM doesn't exit to ES before shutdown? Is there any ScummVM meta data anyway? Or wouldn't meta data from games you played before ScummVM be saved either?
                  meleuM 2 Replies Last reply Reply Quote 0
                    meleu @barrymossel
                    @barrymossel said in Mausberry Shutdown Script Doesn't Save Metadata:
                    Yes for this question.
                    cyperghostC 1 Reply Last reply Reply Quote 2
                      cyperghost
                      @meleu Hmm... and if you make case selection?
                      Are you sure there are no other caveeats? I must admit I'm not very common with the how to kill-a-process method.
                      okay... I will try :)
                      It's not tested, i have no access to my Pi now... So just coded out of brain (Please make the code look better... I use lot's of ifs.... much to much!)
                      emupid="$(sed -n 4p /dev/shm/runcommand.info | tr -d '\\"' | tr '^$[]*.()|+?{}' '.')"
                      emu_com="$("${emupid%% *}")"
                      emupid="$(pgrep -f "$emupid")"
                      if [[ "$emu_com" == "bash" ]] && [[ "$emupid" ]]; then
                          kill -9 $emupid && sleep 4
                      fi
                      You've to check also the PID.... because runcommand.info isn't deleted in ES caroussel mode after emulator is running :)
                        cyperghost @meleu
                        @barrymossel That's the question. You will losse all your progress in metadata saving if anything goes wrong.
                        But to be true.... I'm satisfied with 1.56 - the rest are rare usecases (imho)
                          cyperghost
                          @meleu
                          Annother suggestion
                          [[ "$(ps -p $(expr $emupid + "1") -o comm=)" == "scummvm" ]] && kill $(expr $emupid + "1")
                          That's the way I would do... this is just an idea...
                          I tested this ... worked to kill one additional process with name "scummvm" but I'm not sure if this will always work!
                            meleu @barrymossel
                            @barrymossel Can you please test this script here: https://ghostbin.com/paste/a29wx
                            edit: I mean, test with ScummVM. ;-)
                              barrymossel @meleu
                              @meleu said in Mausberry Shutdown Script Doesn't Save Metadata:
                              Nope, didn't exit to ES and did not save lastplayed from game I started before.
                                cyperghost
                                @barrymossel I knew I made promise do not interact with this code by maybe you can try this one 1.57b - it's just a dirty workaround!
                                Feel free to test!
                                @meleu
                                I don't getting it why it does not work.
                                In generell I would try to detect PPID and then use ps command to find all PIDs stared by PPID.
                                meleuM B 2 Replies Last reply Reply Quote 0
                                  meleu @cyperghost
                                  @cyperghost I think pgrep scummvm (without -f) would be more effective thant that.
                                    barrymossel @cyperghost
                                    Feel free to test!
                                    I just started a massive scrape, so I won't turn the RPi off now. Depending on when the scrape ends I will try it later or tomorrow evening.
                                      cyperghost @meleu
                                      OUTDATED !!
                                      Yes... but I'm finished with that code. But I think using ps as entry to extract PPID should work. So this is a sniplet coded yesterday with annother intention....
                                      Thank you :)
                                      What does happen if you use killall command instead of kill -9 or use killall in general?
                                      @barrymossel
                                      as meleu alread said pgrep would be the smarter approach!
                                      I just want to create failsafe methods but they aren't effective in CPU load :)
                                      so you have to change code line
                                      [[ "$(pgrep scummvm)" ]] && pkill scummvm
                                      or if you are just a killer without p
                                      [[ "$(pgrep scummvm)" ]] && kill "$(pgrep scummvm)"
                                      Sorry for being inconvinient
                                        cyperghost @cyperghost
                                        @meleu @barrymossel @lostless
                                        I think that's it
                                        [[ "$(pgrep -P $emupid)" ]] && kill $(pgrep -P $emupid)
                                        So I would push to v1.58 give this a try! I tested with a bash that called a bash.... It worked great so far!
                                        I also updated the ES PID detector. It shows emulator call PID, PID of child processes and ES PID! @barrymossel You can use the PID detector to proof if all PIDs will be proper detected!
                                        So go... kill'em all (METALLICA??)
                                          I think that's it
                                          Will try tonight, when I find the time...! :)
                                            meleu @barrymossel
                                            @barrymossel please test this one: https://ghostbin.com/paste/adsrw
                                            It has the same logic as the solution above by @cyperghost , I just cleaned up the code. He will update his post soon.
