    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 109.5k Views
      meleu @hansolo77
      @hansolo77 said in Mausberry Shutdown Script Doesn't Save Metadata:
      I dunno, you think I should just use 2 and play it safe?
      IMHO yes.
        barrymossel
        Really nice work guys. Will try later this as well!
        Is v1.7 still under development? Willing to test of course!
        lostlessL meleuM 2 Replies Last reply Reply Quote 0
        • lostlessL
          lostless @barrymossel
          @barrymossel I'm using 1.7 and it working fine.
            meleu @lostless
            @lostless said in Mausberry Shutdown Script Doesn't Save Metadata:
            Can you post a link to the script you're naming as 1.7?
            Or maybe paste it in ghostbin...
              meleu @barrymossel
              @barrymossel said in Mausberry Shutdown Script Doesn't Save Metadata:
              This "development" is more about testing than writing code. I would love to have this device to make more tests. I tried some experimentations with @lostless via IRC but it was late night... If you find me at IRC some day feel free to contact me.
              If I find some time I'll write what tests I would like to do...
              • lostlessL
                lostless @meleu
                @meleu I assumed i was using 1.7. It's what ever the last one @cyperghost posted.
                  barrymossel @meleu
                  @meleu said in Mausberry Shutdown Script Doesn't Save Metadata:
                  Ah, I thought you didn't figure out how to work around the loop yet. I will check in IRC later!
                  • lostlessL
                    @barrymossel we didn't. For some reason the inotify was not reading the change on the gpio. So something is up. What's weird though, is when we manually told the pi there was a change to the gpio, the script worked.
                      cyperghost @lostless
                      @lostless @barrymossel
                      The version 1.56 could be considerd as 1.70 without the inotify-part. It held all code pieces to detect emulators and to finish them and make ES shutdown properly. It uses the 1.0second endless loop that was introduced in the mausberry script.
                      So @meleu is working on 1.70 to break the loop.
                      I'm also interested in 1.70 not using it as power switch rather as a generell switch. I plan to make a small build and this code would improve much.
                      So meleu will "release" two version.
                      1. A shutdown script with better GPIO detection (inotify)
                      2. A shutdown script with 1.0sec loop as introduced in mausberry
                      Why two versions? Simply the inotify package isn't preinstalled!
                      We can all be happy to have one so extrem gifted coder here in our forum.
                      Thank you meleu!
                      Myself got's only a long breath and is willing to learn something new.
                      • CapemanC
                        Capeman
                        Would using a script like this be possible with the retropie powerblock?
                          cyperghost
                          @Capeman
                          Seems so.... But please .... we create annother thread
                            barrymossel
                            v1.56 works for me. SCUMMVM shuts down immediately without exiting to ES. Is that correct?
                            • lostlessL
                              @barrymossel the script is supposed to exit back to es then shut down. Check with other emulators and see if it does that. If not, something is wrong
                                barrymossel
                                Only ScummVM. Probably because than one was an exception. But I don't know whether this would be expected behavior for ScummVM or not. Guess @meleu will tell ;)
                                  cyperghost
                                  @barrymossel Please can you use PID detector and check PIDs displayed?
                                  Use ps -a and check PIDs?
                                    meleu @barrymossel
                                    @barrymossel and post the exact script you're using on ghostbin.com or something.
                                    • CapemanC
                                      Capeman
                                      If there's any powerblock users, this code works without a hitch with powerblock also, just a simple file edit. How elegant and simple, you guys are awesome!
                                      Powerblock proper ES shutdown
                                        barrymossel @cyperghost
                                        @cyperghost said in Mausberry Shutdown Script Doesn't Save Metadata:
                                        Sure, when I get back home. What do you want me to do exactly?
                                        Sure, will do so in some hours.
                                          cyperghost @barrymossel
                                          @barrymossel
                                          1. Post code of your current switch bash to ghostbin.com and give us the link
                                          2. Run emulator ScummVM
                                            2.1 Connect with SSH
                                            2.2 Check PIDs (Process ID) during emulator is running
                                            2.2.1 Use PID Detector script
                                            2.2.2 ps - a if PIDs are equal
                                          if PID detector output one number and you type kill PIDNUMBER then the emulator should close :)
                                          Because you said your script (version 1.56) does not work with ScummVM so let us invetigate.
                                            @barrymossel
                                            I actually didn't say it "doesn't work" with ScummVM. It just looks like it doesn't exit to ES first, but it looks like it goes straight to shutdown. I am just wondering if that is expected.
                                            But I will do the above in a sec.
                                            --- edit---
                                            https://ghostbin.com/paste/jahru
                                            2335 vs. 2336
                                            pi@retropie:~ $ bash pidtest.sh
                                            An emulator is currently running!
                                            It's PID is: 2335
                                            EmulationStation is runnuning!
                                            ES's PID is: 1008
                                            pi@retropie:~ $ ps -a
                                              PID TTY          TIME CMD
                                              992 tty1     00:00:00 bash
                                              997 tty1     00:00:00 bash
                                              998 tty1     00:00:00 emulationstatio
                                             1005 tty1     00:00:00 emulationstatio
                                             1008 tty1     00:00:46 emulationstatio
                                             2245 tty1     00:00:00 sh
                                             2246 tty1     00:00:00 bash
                                             2335 tty1     00:00:00 bash
                                             2336 tty1     00:00:21 scummvm
                                             3415 pts/0    00:00:00 ps
                                            pi@retropie:~ $
                                            And another test: 6901 vs 6902
                                            It's PID is: 6901
                                            ES's PID is: 1008
                                              PID TTY          TIME CMD
                                             1008 tty1     00:01:52 emulationstatio
                                             6815 tty1     00:00:00 sh
                                             6816 tty1     00:00:00 bash
                                             6901 tty1     00:00:00 bash
                                             6902 tty1     00:00:26 scummvm
                                             8210 pts/0    00:00:00 ps
                                            pi@retropie:~ $
