    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 108.0k Views
      meleu @lostless
      @lostless sorry, I didn't understand your last question...
      • lostlessL
        lostless @meleu
        @meleu has nothing to do with the script. that works . i was testing with another memory card without my gpio setup so i had 3.3v through a 10k resistor to the gpio. i think i burned out my gpio pins
        Permissions issue I think. Reinstalled and gpio is now working
          cyperghost @meleu
          @meleu ;) So you see ... PID numbers are better to handle ;)
          But I think in the kodi-case a simple pkill kodi would be better. Or am I wrong? Sorry I never will get the result as I never will install Kodi on my Pi alongside with RetroPie ;)
            meleu @lostless
            @lostless hey man, would you be kind enough to test this version?:
            #!/bin/bash
            # the "sed" command below isn't a crypted message, it's just a Regular Expression
            # If you are very curious, feel free to ask.
            emucall="$(sed '4!d; s/\([\\"]\|[[:alnum:]_]\+=[^ ]* \)//g; s/[][(){}^$*.|+? ]/\\&/g' /dev/shm/runcommand.info)"
            # If there's an emulator running, we need to kill it and go back to ES
            if [[ -n "$emucall" ]]; then
                emupid="$(pgrep -f "$emucall" | tr '\n' ' ')"
                pkill -P "$(echo $emupid | tr ' ' ',')"
                kill "$emupid"
                wait "$emupid"
                sleep 5 # maybe it can be lesser
            fi
            Thanks in advance.
            lostlessL 1 Reply Last reply Reply Quote 1
            • lostlessL
              lostless @meleu
              @meleu sorry, not working
              debug output
              /home/pi/exit.sh: line 4: unexpected EOF while looking for matching `)'
              /home/pi/exit.sh: line 14: syntax error: unexpected end of file
                meleu @lostless
                @lostless ooops! my fault. I edited the script above fixing the problem. can you please try again.
                • lostlessL
                  lostless @meleu
                  @meleu all good.
                    meleu @lostless
                    @lostless does it mean it works? :)
                    • lostlessL
                      lostless @meleu
                      @meleu yes its working
                        meleu @lostless
                        @lostless thanks man! ;-)
                        lostlessL 1 Reply Last reply Reply Quote 2
                        • lostlessL
                          lostless @meleu
                          @meleu My nespi is practically done. The reset is working wonderfully,
