    FC30 Pro not working with retroarch
    8bitdo fc30 proretroarchcontroller
    3 Posts 2 Posters 921 Views
      shingouki
      I have a FC30 Pro with the latest firmware, the controller works in ES but not all buttons works in retroarch for the SNES emulator
      anyone has any idea how this can be fixed?
      below is the content of /opt/retropie/configs/all/retroarch/autoconfig/8Bitdo FC30 Pro.cfg
      input_device = "8Bitdo FC30 Pro"
      input_driver = "sdl"
      input_up_btn = "h0up"
      input_down_btn = "h0down"
      input_left_btn = "h0left"
      input_right_btn = "h0right"
      input_a_btn = "0"
      input_b_btn = "1"
      input_x_btn = "3"
      input_y_btn = "4"
      input_l_btn = "6"
      input_r_btn = "7"
      input_l2_btn = "8"
      input_r2_btn = "9"
      input_l3_btn = "13"
      input_r3_btn = "14"
      input_select_btn = "10"
      input_start_btn = "11"
      input_l_x_plus_axis = "+0"
      input_l_x_minus_axis = "-0"
      input_l_y_plus_axis = "+1"
      input_l_y_minus_axis = "-1"
      input_r_x_plus_axis = "+2"
      input_r_x_minus_axis = "-2"
      input_r_y_plus_axis = "+3"
      input_r_y_minus_axis = "-3"
      input_enable_hotkey_btn = "10"
      input_exit_emulator_btn = "11"
      input_save_state_btn = "9"
      input_load_state_btn = "8"
      input_reset_btn = "14"
      input_menu_toggle_btn = "13"
        edmaul69 @shingouki
        @shingouki thats all correct. Check if you have a controller config for a controller called szmy-powerLtdJoypad. It is also a config for the fc30 pro and nes30 pro. If you have it make sure it matches. Can you use pastebin.com to post the contents of your file /opt/retropie/configs/snes/retroarch.cfg
          shingouki @edmaul69
          @edmaul69
          Please see below:
          https://pastebin.com/aJy8Brue
