    shell scripting topic
    shellshell scriptprogramming
    191 Posts 10 Posters 96.1k Views
    • hansolo77H
      hansolo77
      I'm intrested in developing a script that will generate a custom list for my GameEx High Scoring Competition. GameEx is a frontend I use on my PC, and our forums have created a competition for it's users. I'm actually the primary moderator for that forum. We have a utility for keeping track of scores and generating forum tables. It's all nice and good. I came up with an idea to generate a map file, which allows you to create a "custom list" menu inside GameEx, so you can instantly get into a game that is available for posting high scores with. It works great. I was looking to do something like that for RetroPie too. My PC's keyboard no longer works, and the only way I can use that PC is through RemoteDesktop. However, I have all the games on my Pi, so why can't I just use that?
      Here's a breakdown of what I need to accomplish:
      • Upon turning on the system, as part of the boot process, have a script go out and download the updated list of games from a server. The utility we use to track scores already generates this list and uploads it somewhere, so I just need something to grab it. wget perhaps?
        • This may not need to be done during EVERY bootup.. in fact it might not even work if there is no internet available.
        • Maybe the script should just be available for manual launching? We only add new games every 2 months now.
      • After getting the list, it needs edited to work with EmulationStation's custom list features, as by default the list is probably not directly usable.
      • Save the edited list as a custom list file, in the appropriate folder for EmulationStation to pick it up.
      For reservation, here is the map file:
      http://gameinfo.hfc-essentials.com/hiscore/HiScore.map
      And here is a MAME favorites ini file:
      http://gameinfo.hfc-essentials.com/hiscore/HiScore.ini
      I'm not sure which file would be easier to work with. But if you look at them, it should be easy enough to figure out the editing that needs to happen. Can detailed editing of the file be done automatically via a script? I wasn't sure so I thought I'd ask here. I also asked our developer of the tool we use to see if he can update the tool to also spit out a plain text list.. Looking to see what can happen, or happens. I'd just like a bit of hand holding, not really asking somebody to step in and do all the work (would be nice but I can't learn scripting without practice!).
      What are your suggestions or recommendations?
      Who's Scruffy Looking?
        mitu Global Moderator @hansolo77
        @hansolo77 It can be done. This is how I'd do it.
        1. Download the .map file (curl/wget) locally. Should be text only. Check for errors or if the file is empty and exit if so.
        2. Read the file line by line, split it in col1 (zip name) and col2 (game name). For each col1:
          • Look in the gamelist for the arcade system to search for col1.zip, either via grep or xmlstarlet. [1]
            The idea is to get the path to the ROM zip file as the value into path
          • If you found the path, then check if arcade_folder_path/path exists and if so, add it to a list (list_rom).
          • Repeat steps above if your rom might be in a different system (i.e. mame2003-libretro, fba) and nothing was found in the previous step.
        3. At the end, walk over list_rom and produce a custom collection file in $HOME/.emulationstation/collections/custom-GameEx.cfg containing one line for each ROM path in the list. If a previous .cfg fie exists, back it up.
        You should have to create the collection before running the script so you can choose in ES to make it visible, but once ES knows to show it, I think you only need to restart ES after each script run.
        The above assumes you only have arcade ROMs, since the naming is standard. Make sure to lowecase the col1 in step 2 (I've seen that TMNT is uppercase, but the zip name should be lowercase and
        [1] - get the path of rom using xmlstarlet and ROM name.
        $ xmlstarlet sel -t -v "//game[contains(path,'1943.zip')]/path" .emulationstation/gamelists/arcade/gamelist.xml
        # outputs:
         ./1943.zip
        • hansolo77H
          hansolo77
          I knew it could be done! :) Now to just decipher all that and make a script lol. I’m on vacation after next week, maybe I’ll try to work on it then!
          • hiulitH
            hiulit @meleu
            @meleu @mitu What I'd like to achieve is getting the screen resolution of the device that is/will be using Fun Facts! Splashscreens. And I've seen that it differs from different systems.
            My little contributions to the RetroPie project:
            • Shell-Script-Boilerplate
            • Fun-Facts-Splashscreens
            • Limit-Last-Played-Games
              meleu @hiulit
              @hiulit said in shell scripting topic:
              Uhmmm... maybe what you need is slightly different than just detect whether the user is running your script while in a x11 environment or not.
              If you need to discover if the emulators you installed/compiled on your RetroPie were for use on a X11 environment, I suggest you to try the isPlatform function. You can do something like this:
              . $HOME/RetroPie-Setup/scriptmodules/helpers.sh
              . $HOME/RetroPie-Setup/scriptmodules/system.sh
              if isPlatform "x11"; then
                  echo "Your emulators runs on a X11 environment"
              else
                  echo "Your emulators does NOT run on a X11 environment"
              fi
              Regarding resolution discovering techniques, you are surely ahead of me on this subject. :-)
              I hope it helps.
              hiulitH 1 Reply Last reply Reply Quote 0
              • hiulitH
                hiulit @meleu
                @meleu My problem was that I had these xdpyinfo functions to get the screen resolution and they were working in my VM running Pixel, but when I tried them on the Raspberry Pi I got an error, something like: xdpyinfo: command not found. I tried sudo apt-get xdpyinfo but it didn't work, so I manage to found another way to get the screen resolution from a Raspberry pi, and that's where these fbset -s functions come from.
                So now I need to know when do I need to use one function or the other.
                What I have right now (and seems to be working) is:
                function get_system_platform() {
                    . "$home/RetroPie-Setup/scriptmodules/helpers.sh"
                    . "$home/RetroPie-Setup/scriptmodules/system.sh"
                    get_platform
                    echo "$__platform"
                function get_screen_resolution_x() {
                    if [[ "$(get_system_platform)" != "x86" ]]; then
                        local screen_resolution
                        screen_resolution="$(fbset -s | grep -o -P '(?<=").*(?=")')"
                        echo "$screen_resolution" | cut -dx -f1
                    else
                        xdpyinfo | awk -F '[ x]+' '/dimensions:/{print $3}'
                    fi
                function get_screen_resolution_y() {
                        echo "$screen_resolution" | cut -dx -f2
                    else
                        xdpyinfo | awk -F '[ x]+' '/dimensions:/{print $4}'
                    fi
                  mitu Global Moderator @hiulit
                  @hiulit xdpyinfo is part of the x11-utils package (https://packages.debian.org/stretch/x11-utils), so it's not installed if you're not installing an X.org env (like in Raspbian Lite). But even if it is installed, it only works in a X.org session (desktop environment), otherwise it will return an error.
                  • hiulitH
                    hiulit @mitu
                    @mitu So then, would it be save to use something like this?
                        if [[ $DISPLAY ]]; then
                            xdpyinfo blah, blah...
                        else
                            do_something_for_none_X_org_session
                        fi
                      meleu @hiulit
                          else
                          fi
                      eh... did you read my last post above? I think it answers exactly what you asked on your last post.
                      • hiulitH
                        hiulit @meleu
                        @meleu Yeah, I read it, but I thought it was a different thing, because you said:
                        and don't know if I want/need to know if the emulator is compiled for X11 but rather if the machine is running X11. Or at least that's what I think.
                        I'm really not sure if I'm not explaining myself clearly or if I'm not understanding you, but just in case, I'll try it one more time :P, hehe!
                        I need to get the screen resolution of the machine running RetroPie. How can I have a cross-platform solution? Because the Raspberry Pi has one method of getting the screen resolution and my VM running Pixel has another one (and maybe another platform will have another method)
                        Sorry again @meleu and @mitu if I'm not being clear enough. Or if I'm not asking the right questions.
                        Thanks!
                          cyperghost
                          @meleu Thanks for your Pull-Request on BashROMManager
                          It's not just cosmetic ;)
                          I also resolved a small bug that would prevent us from using the FastForward feature
                          So version is 0.79 now and I think it's a solid codebase for improvements and for changing coding style... step by step
                          @hiulit You are also welcome to give your input here
                          We are talking about here: https://github.com/crcerror/RetroPie-RPM-BashROMManager
                          hiulitH meleuM 2 Replies Last reply Reply Quote 2
                            meleu @hiulit
                            @hiulit Here are some info that looks like you're not aware (and is confused because of it):
                            • X is the graphical server for UNIX systems (including Linux).
                            • the resolution on a pure command line (the one you're getting with fbset) is different than the resolution when you are on a X environment (the one you're getting with xdpyinfo).
                            • The emulators installed by RetroPie on a Raspbery Pi do NOT need a X environment.
                            • The emulators installed by RetroPie on a Linux-x86 system needs a X environment.
                            • If you are on a Raspberry Pi and startx (or whatever command you use to start the graphical interface) you'll have the $DISPLAY variable, but it does NOT mean that you run the emulators on X. Therefore, when you show your launching image (with a fun fact on it) you will NOT necessarily be on the resolution you detected with your current method.
                            Even after all this stuff being said, I wouldn't bother that much to detect the resolution with this degree of precision. In my opinion you should focus only on keeping the aspect ratio of the image you're using for background, this would be enough.
                            If you show me exactly where in the fun-fact's code you want/need this and I can try to be more helpful.
                            • hiulitH
                              hiulit @cyperghost
                              @cyperghost Yeah, thanks! I've been following the thread ;) I'll dig in when I have the time. Good job!
                                meleu @cyperghost
                                @cyperghost I strongly recommend you to take a look at @hiulit 's work on the retropie-shell-script-boilerplate.sh (I believe he would give this input also). I also worked on that template.
                                I was about to submit a new PR when I realized that you would take some advantage looking at that code. ;-)
                                @hiulit what do you think about focusing on aspect ratio instead of trying to detect the exact resolution?
                                hiulitH cyperghostC 2 Replies Last reply Reply Quote 1
                                • hiulitH
                                  hiulit @meleu
                                  @meleu Hey sorry, yeah, maybe you're right! But then, should I have a predefined resolution? Like 1080p, 720p, 800x600 and let the user decided which size to use?
                                    meleu @hiulit
                                    I'm not confident enough to say what you should do :), but I can say what I do on my launching image generator tool.
                                    I'm currently away from my dev machine to confirm, but IIRC the command below is what you need to resize an image to a height of 576 pixels. The resulting_image's width will be the one necessary to keep the same aspect ratio of the original_image.
                                    convert -resize x576 original_image resulting_image
                                    EDIT: confirmed. The command above works exactly as I described.
                                    By the way, I noticed you're commiting experimental stuff (such as this resolution thing you were discussing above) directly on the master branch of the fun-facts repo. This is NOT a good practice. ;-)
                                      cyperghost @meleu
                                      This post is deleted!
                                        cyperghost
                                        @meleu Yes I used your function call. Works nice.
                                        Is there anything against the return $value method?
                                        Or am I abusing the being of $? as method to check if a function/command gave return code =0 for okay and !=0 for errors?
                                        So thx... pushed BashROMManager to v080 now.
                                        Do you have any suggestion in the use of xmlstarlet or better use grep?
                                        Maybe the script can be extended to clean also image-files and videos related to it - version 2.x?
                                        • hiulitH
                                          hiulit @meleu
                                          @meleu Yeah! I know! I should've created a new branch for this new feature.. :P But It is safe to use master because I made the code backwards compatible, so nothing that was already there is broken and the new things aren't even documented yet. When using git for yourself (at least for me) you tend to use bad practices because it's easier, hehe!
                                          A part from that, I see you point of just using height to maintain the aspect ratio, but I don't know how can I can create images for different resolutions that will look good on every device. I mean, if I use, let's say, the 576px you said, it will look too small on a 1920x1080 screen, I think. I'll give it a try anyway to see how "bad" (or good!) it looks. Thanks, as always! ;)
                                            meleu @hiulit
                                            My tool generate launching images with 576 pixels height and keep the aspect ratio of the image being used as background, Rokkervik's pixel-themed launching images are 480x272. All of them looks just fine on my 1920x1080 TVs...
                                            If you create launching images 1920x1080 the resulting file can be very big and the raspberry pi can delay to display a big image
                                            hiulitH 1 Reply Last reply Reply Quote 1
