    [PROJECT]My first home-made console
    projectconsoleretropie
    7 Posts 3 Posters 2.6k Views
    • retroprogrammerR
      retroprogrammer
      Hi guys I just wanted to start my first proper Retro-pie project and I thought why not share it to the world so lets get started :)
      Right now I am searching for a retro console like a SNES, NES, PS1, PS2, Atari 2600 to put my raspberry-pi 3 in and tomorrow I will be going to a flea market to see if they have anything.If anyone has done I project like this please post because this is my first project, I have done some tutorials in the past so please feel free to check them out. Also I was hoping someone knows how to use the SNES, NES, PS1, PS2 ports to work with raspberry-pi 3 and retropie.
      I will be updating this post nearly everyday so please check in!
      Here is me converting the original Xbox for a case:
      https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
      Check out my GitHub: https://github.com/retro-programmer
      • retroprogrammerR
        retroprogrammer
        Hi guys here is a update of my project,well today I want shopping and found a good deal for a x-box for $35 and thought it was perfect. It comes with a few games preloaded and a controller it also came with a "X-BIT"
        I'm not really sure what it is for as I am not a big xbox player so if any one knows what it is I would be thankfull it also came with an extra attachment which I don't know what it does and some other stuff here are some pictures:
        here is the back with the mysterious X-BIT
        and here is the X-BIT in full view
        here is the xbox with the extra component connected, I am not sure what it does
        • retroprogrammerR
          retroprogrammer
          should I keep the xbox or turn it into a retro emulator? can anyone help thanks in advance
          • N
            NizZ8
            You can do both, there are a decent amount of emulators you can run on a modded xbox. Here is an article you can reference as a starting point -- http://www.retrogamescollector.com/emulation-cheap-using-original-xbox-part-1-what-can/
            • retroprogrammerR
              retroprogrammer
              thanks for the post has anyone else made anything like this I am not sure if I should break it apart our keep it like it is any one know what the x-bit is?
                edmaul69 @retroprogrammer
                @retroprogrammer just so you know the x-bit is a mod chip. You can put emulators on it the way it is.
                • N
                  NizZ8
                  Check out CoinOps 8, can't post a direct link here but it's a pretty slick emulation package for the OG Xbox.
