    Need a small PI speaker powered through 3.5mm or usb
    pi speakers
    20 Posts 4 Posters 5.6k Views
      dunginhawk
      Good evening... I am in need of a speaker (1-2) that can be powered by the raspberry pi usb port, or the 3.5mm jack.
      Basically the only power cord I want going in to my mini cab is the power for the PI (im using a 7" pi display, so i can share power).
      I dont need booming sound, just enough to play some mame games with it.
      Any idea where I can find a small set of speakers that will at the very worst power off the PI usb?
      thanks
      pjftP caver01C 2 Replies Last reply Reply Quote 0
        pjft @dunginhawk
        @dunginhawk The 3.5mm jack does not power anything. You can try to find some non-powered speakers to plug in there, though. As for USB powered speakers, I personally know none, and while I'd imagine there could be some, there's the chance that a USB port will not deliver enough power.
        • Z
          Zigurana
          I use the logitec S150 usb speakers, which have plenty of oomph for my small bartop.
            dunginhawk @Zigurana
            @zigurana do you power those speakers off your pi? or a separate usb power source?
            • Z
              Zigurana
              I power everything via the Pi itself, but then again, I use a 5A power supply.
                @zigurana also, these measure very big :) I need something in the 2 " cube max size... Yeah i will be using a 5amp power supply as well. thank you zig
                • Z
                  Zigurana
                  Well, I don't know your situation, but I dismantled them, using only the usb-panel and the drivers themselves. Those are maybe 7 cm in diameter, and 5 cm deep, so I was able to just squeeze them in my bartop.
                    dunginhawk
                    ok.. thank you sir... ill hold it as an option..
                      dunginhawk @dunginhawk
                      zig. would you happen to have a link to a 5A PS for the pi? most i can find are 5v 2-3a
                      thanks
                        @dunginhawk or perhaps you meant 5v smaller amp? 5 and 5 seems off.. but id love it if it exists.
                        • Z
                          Zigurana
                          I have something very close to this:
                          Single Output Switching power supply 5V 5A 25W Transformer 110V 220V AC To DC 5 V SMPS For Electronics Led Strip Display
                          • caver01C
                            caver01 @dunginhawk
                            @dunginhawk I used these speakers in my cabinet. They are connected to the 3.5mm and powered via USB. I un-shelled them and put the drivers into PVC tubes. Not sure if they would fit in your projects, but the amp kicks out adequate sound and has a tiny potentiometer to adjust volume (although I have it cranked to max and adjust digitally).
                              dunginhawk
                              Caver01.. thanks.. ive seen those around... it may be worth picking up a pair to test.
                              Right now I just bought a 9.99 bluetooth speaker that I can connect via 3.5mm and it will charge through the USB on the pi.
                              I think that should work. Sound is much less important to me (dual channel etc).
                              thanks
                                dunginhawk
                                Son of a ???? so this little speaker, while it will charge through the USB on the pi, the feedback at rest is loud.
                                https://www.amazon.com/gp/product/B00BYRPKEO/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                                once in a game its perfect, but there are no volume controls on the speaker itself to turn it down.
                                man this is a chore.
                                D caver01C 2 Replies Last reply Reply Quote 0
                                  this shouldnt be that hard.
                                  Requirements.
                                  1. USB for power (500Mamp or less draw preferably)
                                  2. Volume control on the Speaker (the pi is just too loud until its in game).
                                  3. 2" cube or smaller
                                  4. 3.5mm for audio
                                  anyone? :)
                                  • caver01C
                                    caver01 @dunginhawk
                                    @dunginhawk said in Need a small PI speaker powered through 3.5mm or usb:
                                    Is this the old audio hiss problem that is present on the 3.5mm jack? You can fix that with this command in config.txt:
                                    disable_audio_dither=1
                                    I am also following this thread regarding the use of a newer audio driver that is supposed to fix both the his and dramatically improve the quality of the 3.5mm.
                                    I currently use the command above and have not tried the new driver yet as I am away from my Pi for a few days. Have you tried either of these?
                                      dunginhawk
                                      reading through that thread now.. the first suggestion didnt do anything to address the hissing :)
                                      thanks...
                                        wait just one minute :) i misread your statement... I ran it from the command line instead of adding to the config.txt and it appears to be working...
                                        Sweet jesus. thank you SOOOO much.
                                        I do notice the sound is a bit crunchy in NES games, but the mame ones sound great.
                                          dunginhawk
                                          So I am looking at how to edit this
                                          Update the retroarch.cfg file with audio_out_rate = 44100 Using that config the ALSA sound coming from the headphone jack is a lot clearer and has a lot less static.
                                          I have searched winscp, and all over trying to locate this file to edit it. but cant seem to find that.
                                          the sound is great in mame, but is really fuzzy in NES, hoping this helps.
                                          EDIT - screw it... im giving these away, they can deal without NES games :) stick with mame, sound is good.
                                          • caver01C
                                            caver01 @dunginhawk
                                            @dunginhawk the retroarch configs are described here. This page is about controller configuration, but the paths are there. You probably want to edit the global config. Just remember, these settings only affect libretro core emulators, not stand-alone.
