    Help hotkey not in configure controller??
    hotkey exit
    2 Posts 2 Posters 521 Views
      RetroFreak89
      I think ive got an issue
      I bought a new SD card and burned a copy of retropie on it and you know when you first boot it ask to configure your controller?
      Well all the options weer there exept for the last one there was no option to set the hotkey the hotkey is no longer there??
      This is the new 4.2 retropie image but since the hotkey is not there how the heck Will i be able to back out and exit emulators...
      What do i do??
      • DarksaviorD
        Darksavior @RetroFreak89
        @retrofreak89 The retropie image is from March. Update it to latest and then the hotkey option will be there. Though, you can still set up retropie without the hotkey option and it'll bind the default of select+start.
