    No updates done. Fresh SD and flash, Cannot see wifi AP's there are 2 next to me. 'Resolved'
    no wifi
    8 Posts 3 Posters 1.7k Views
    • XeonX
      Xeon Banned
      Something very wrong with builds for the pi 0
      That is now 3 weekends wasted with something wrong after a fresh install on a samsung evo memory card, how do you reach the point where you wait 24 hours for it to update everything?
      • XeonX
        Xeon Banned
          dankcushions Global Moderator
          fill out this https://retropie.org.uk/forum/topic/3/read-this-first
          don't bump posts please. if no ones answering is likely there's not enough info.
          • XeonX
            Xeon Banned
            Pi Model or other hardware: Zero
            Power Supply used: 5v 2A
            RetroPie Version Used 4.2
            USB Devices connected: canyon wifi dongle, compaq usb keyboard"hp chipset"
            Controller used: keyboard
            Error messages received: none
            unable to scan for AP's shows a option 0 in the menu with no description
            Below that the option to disconnect from a AP that does nothing.
            Currently not connected via wifi to anything.
              pjft
              Still not clear. What is the actual problem you're experiencing? Do you get an error message? Are you trying to update without being connected to wifi? Without more information this is like stumbling in the dark. Yes, the pi 0 is slower. If you're updating everything from source, it will take a lot of time. That is expected, unfortunately. MAME and EmulationStation in particular can take quite a bit.
              • XeonX
                Xeon Banned
                Very simple.
                i cannot get connected to the wifi because it wont give me the option in the menu.
                i get no error message.
                this is a fresh verified download and flash on a fresh memory card.
                This did work 2 weekends ago but i had to wipe because the sound stopped working.
                last weekend i was trying to update and i kept having dns resolution errors on a wired connection.
                i cannot use retro pie because there is always something that goes wrong.
                  pjft @Xeon
                  @xeon take RetroPie out of the equation and go down to the basics then. Connecting to wifi is a system thing.
                  Get to the terminal and try to connect. See if these
                  https://learn.adafruit.com/adafruits-raspberry-pi-lesson-3-network-setup/setting-up-wifi-with-occidentalis
                  Or similar posts help (this was the first Google result, I'm not sure if it's the best, but you get the idea).
                  The DNS errors don't inspire confidence in any way. The missing options probably mean it's not fully detecting or activating your dongle. Can be missing drivers, faulty dongle, low power, myriads of things. It may even be a wifi region and channel thingie - what channel does your router broadcast in? Some regions don't allow specific channels to be used, so your hardware will need to be set to a different region if that's the case.
                  • XeonX
                    Xeon Banned
                    Thanks buddy
                    after checking again i saw the power supply was spitting out 4.3V+- so the wifi dongle was not powering properly.
                    I feel really dumb.
                    'power supply is now in trash'
