    Alsa Problem, I Think
    playstation 2alsa
    4 Posts 2 Posters 1.5k Views
      billybag
      Hey guys
      It has been a while (busy with school and such) since i have used my retroPie for anything other than Kodi, but i still kept it up-to-date and i think that is where something went wrong.
      i cannot load any of my playstation games (i believe they are all PS2 games if that matters)
      Here is the log file
      [code]Parameters:
      Executing: SDL1_VIDEODRIVER=dispmanx pushd /opt/retropie/emulators/pcsx-rearmed; ./pcsx -cdfile "/home/pi/RetroPie/roms/psx/Kingdom Hearts II.iso"; popd
      /opt/retropie/emulators/pcsx-rearmed ~
      warning: video overlay is not hardware accelerated, not going to use it.
      plat_sdl: using 1824x984 as fullscreen resolution
      plat_sdl: overlay: fmt 59565955, planes: 1, pitch: 1280, hw: 0
      input: new device #0 "sdl:keys"
      input: new device #1 "sdl:Sony PLAYSTATION(R)3 Controller"
      input: async-only devices detected..
      drv probed binds name
      0 0 y y sdl:keys
      1 0 y y sdl:Sony PLAYSTATION(R)3 Controller
      frontend/libpicofe/readpng.c: failed to open: /opt/retropie/emulators/pcsx-rearmed/skin/font.png
      frontend/libpicofe/readpng.c: failed to open: /opt/retropie/emulators/pcsx-rearmed/skin/selector.png
      menu_load_config: failed to open: ./.pcsx/pcsx.cfg
      frontend/libpicofe/readpng.c: failed to open: /home/pi/.picodrive/skin/background.png
      me_id2offset: id 28 not found
      Starting PCSX-ReARMed
      Running PCSX Version 1.9 (Jul 16 2017).
      warning: failed to do hugetlb mmap (0x80000000, 2162688): 22
      warning: mmaped to 0x73701000, requested 0x80000000
      psxMap: warning: wanted to map @80000000, got 0x73701000
      Init new dynarec
      testing if we can run recompiled code..
      test passed.
      warning: RAM is not directly mapped, performance will suffer
      Mapped (RAM/scrp/ROM/LUTs/TC):
      77000000/1f800000/1fc00000/08000000/008af000
      Loading memory card ./.pcsx/memcards/card1.mcd
      Loading memory card ./.pcsx/memcards/card2.mcd
      plugin: plugins/builtin_gpu
      plugin: plugins/builtin_spu
      plugin: plugins/builtin_pad
      Plugins loaded.
      Loaded CD Image: /home/pi/RetroPie/roms/psx/Kingdom Hearts II.iso[2048].
      alsa: using 'bcm2835 ALSA', set ALSA_NAME to change
      selected sound output driver: alsa
      ari64_reset
      Could not load CD-ROM!
      [/code]
      Sorry about all the text, i thought code tags worked here
      thanks.
      CapemanC 1 Reply Last reply Reply Quote 0
      • CapemanC
        Capeman @billybag
        @billybag said in Alsa Problem, I Think:
        Yes that matters. Retropie cannot play Playstation 2 games. Only PS1.
          billybag
          This post is deleted!
            billybag @Capeman
