    FBA sound issues
    fbasound
    6 Posts 3 Posters 1.6k Views
    • ExarKunIvE
      ExarKunIv
      Pi Model or other hardware: (Pi3)
      Power Supply used: (5 v 2.52amp)
      RetroPie Version Used (4.2.10 from 4.2):
      Built From: (Pre made SD Image on RetroPie website)
      with what goes in to getting the different arcades up and going i wanted to ask before i spent anymore time on this.
      i have been trying different games on FBA, which i have updated to 0.2.97.42, and i have complied all the roms with the correct DAT file.
      i still have sound issues with a few games, After burner, and altered beast are the two have always have sound problems.
      The sound is very very choppy and slow
      is there anything that can be done or should i try a different EMU for them?
        bengus
        Altered Beast and Afterburner both work perfectly for me, sound fine. However, I do remember Altered Beast sound being off (voice samples were not correct) prior to ver0.2.97.40. Are you sure you are using a complete/correct romset?
        • ExarKunIvE
          ExarKunIv @bengus
          @bengus
          as far as i know yes. i have played it with the windows version of FBA and they both sound fine, but on the Pi not so much, for me that is
          • DarksaviorD
            Darksavior @ExarKunIv
            @exarkuniv The system16 emulation in fba has always been slower than mame. Even with the recent fba update that fixed its sound issues. While mame 2003 can play those games, the sound accuracy might be off. You can try mame 2010.
            • ExarKunIvE
              ExarKunIv @Darksavior
              @darksavior
              ok cool. ill give that a shot. i just did not want to waste the hours to compliethe roms just to have it be the same,
              • ExarKunIvE
                ExarKunIv
                well i tried mame2010 sound is still the same
                i will try and hunt down a different rom packs and try again with fresh roms
