    N64 launch issue with lr-mupen64plus with fresh setup and compile
    n64
    2 Posts 1 Posters 1.1k Views
      retrogamer2 Banned
      Hello, seem to having issues launching the n64 roms when retropie is installed andcompiled from scratch below is my /dev/shm/runcommand.log
      INFO] none [INFO] Environ GET_VARIABLE mupen64plus-pak4: [INFO] none [INFO] Environ SET_HW_RENDER. [INFO] Requesting OpenGLES2 context. [libretro ERROR] mupen64plus: libretro frontend doesn't have OpenGL support.[ERROR] Failed to load content. [INFO] [PERF]: Performance counters (libretro): [INFO] Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg" [INFO] [Video]: Does not have enough samples for monitor refresh rate estimation. Requires to run for at least 4096 frames. [ERROR] This core requires a content file.
      using raspberrypi 3
        retrogamer2 Banned
        Solved it by updated to latest version.
        This can be closed.
