    Amiga and DosBox emulators not showing
    amiga uae4armamiga retropiedosbox
    33 Posts 11 Posters 7.4k Views
      gordonfreemanjr @maxbeanz
      @maxbeanz
      Done that. Still nothing. It's getting ridiculous.
      RPi 4 4GB
      Retropie v 4.7.1
        dankcushions Global Moderator @gordonfreemanjr
        @gordonfreemanjr it's case sensitive. k not K
          gordonfreemanjr @dankcushions
          @dankcushions said in Amiga and DosBox emulators not showing:
          Thanks. Uncapitalized the K's, copied over again, restarted. Still no Amiga emulator.
          RPi 4 4GB
          Retropie v 4.7.1
            edmaul69 @gordonfreemanjr
            @gordonfreemanjr why do they have an asterisk * in front of them?
              gordonfreemanjr @edmaul69
              @edmaul69 said in Amiga and DosBox emulators not showing:
              I have noticed that all roms have it, not only Amiga roms (and they work), even those that were there originally (as in: not inserted by me).
              RPi 4 4GB
              Retropie v 4.7.1
                @gordonfreemanjr is 'parse gamelist only' turned on in ES options? turn it off if so, and restart.
                  It's off and 'save metadata' is on.
                  RPi 4 4GB
                  Retropie v 4.7.1
                    gordonfreemanjr @gordonfreemanjr
                    Any ideas left, guys?
                    RPi 4 4GB
                    Retropie v 4.7.1
                      BuZz administrators @gordonfreemanjr
                      @gordonfreemanjr what files do you have in /opt/retropie/configs/all/emulationstation ?
                        gordonfreemanjr @BuZz
                        @buzz said in Amiga and DosBox emulators not showing:
                        6 files, 1 folder. Here they are:
                        RPi 4 4GB
                        Retropie v 4.7.1
                          @gordonfreemanjr you have a custom es_systems.cfg there. This overrides the RetroPie one. Delete it and the new systems will show up. You or whoever set this up must have copied it there to customise the systems list.
                            @buzz
                            And it... WORKS FINALLY, after 8 days! Amiga, Scumm and DosBox have all popped up instantly after restart. Thank you guys. I'd never make it work without your help.
                            To recap the procedure:
                            • YES, create the 'amiga' folder if nonexistent;
                            • NO, do not create amiga lines in the .cfg file, leave it be;
                            • YES, check the 'retropie setup' section if the necessary emulators are installed, if not - install from source;
                            • YES, remember the kickstart roms correct placing and filename format;
                            • YES, move a few .adf's to the 'amiga' folder.
                            RPi 4 4GB
                            Retropie v 4.7.1
                            • herb_fargusH
                              herb_fargus administrators @gordonfreemanjr
                              @gordonfreemanjr said in Amiga and DosBox emulators not showing:
                              These are unnecessary as they are handled automagically when the emulator is installed from the setup script
                              And installing from source is generally not recommended if binaries are available
