    PSX Cheat Help...
    cheatpsxpsx cheat
    3 Posts 2 Posters 1.5k Views
    • EcksE
      Ecks
      Hi guys i was trying to play SD Gundam G Generation F and well i just wanted to play again with max money but when i add in the code to the list and such it shows up as N/A and when i enable it the game crashes so i would like to know what i might be doing wrong.
      This is how i loaded it but like i said when i try to enable it it shows as N/A.
      • herb_fargusH
        herb_fargus administrators
        Might be one of those multiline code doohickies.
        So I vaguely remember when testing that for some reason add the lines together the syntax broke it even though it should work but it didn't.
        Try formatting it like the example in the docs:
        https://retropie.org.uk/docs/Cheats/#multiline-cheat-codes
        Other relevant post here:
        https://retropie.org.uk/forum/topic/1882/having-problem-with-adding-multi-code-cheats-solution
        EcksE 1 Reply Last reply Reply Quote 0
        • EcksE
          Ecks @herb_fargus
          @herb_fargus Ok thanks ill look into those also wish i could load my save from SD Gundam G Generation F to F.i.f but it makes a separated save file instead.
