Strange Issue with CRT
@akafox Actually I added the framebuffer lines under the overscan lines (used 320 and 240) and it fixed the issue! But only in the terminal...
Any suggestions?
strange..are using advmame? you might have to tweak the settings in the admame.rc
@akafox No, RetroPie is completely ignoring the config.txt settings...
Ok I think I finally fixed it to the point where it doesn't make me angry. I decided to try someone else's config.txt as mine was cursed or something :P I went here: https://www.dropbox.com/sh/6hdpa7893c3ked1/AABCXqUHjXI-C3PUdcq4f8jya?dl=0 and downloaded the "custom_res" config. I renamed it to "config.txt", changed the resolution to 320x240, and added some custom overscan numbers. The lines are still there, but they don't affect the text and only appear on a black screen. I'm sure I could go further and 100% fix it but right now I'm happy. Whew!
