    Assigning jstest output to a variable from a shell script
    jstestshell scriptjoystickpressesbuttons
    1 Posts 1 Posters 843 Views
    • madmodder123M
      madmodder123
      I tried using this to assign the output of jstest to a variable, but it seems like jstest just opens and the script does not continue.
      JSTEST_OUTPUT_2=$(jstest /dev/input/js1)
      This is the command and the output I am trying to capture:
      Driver version is 2.1.0.
      Joystick (Twin USB Joystick) has 6 axes (X, Y, Z, Rz, Hat0X, Hat0Y)
      and 12 buttons (Trigger, ThumbBtn, ThumbBtn2, TopBtn, TopBtn2, PinkieBtn, BaseBtn, BaseBtn2, BaseBtn3, BaseBtn4, BaseBtn5, BaseBtn6).
      Testing ... (interrupt to exit)
      Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 Buttons: 0:off 1:off 2:on 3:off 4:off 5:on 6:off 7:off 8:off 9:on 10:off 11:off
      I also tried using grep (jstest --normal /dev/input/js1 | grep ".*") just to see what would show up and it would only return:
      I am not sure why it wouldnt capture the button/stick data (maybe because it's values are constantly being updated?)
      I dont care about the other information i just want this:
      I will keep searching the internet for an answer and I will update this post if I find one.
      Thanks guys!
