    Wifi problem
    wifiedimax ew-7811unespi case
    4 Posts 3 Posters 1.4k Views
      Sander2506
      Pi Model or other hardware: (2 B)
      Power Supply used: (Samsung 5v 2a model:EP-TA20EWE)
      RetroPie Version Used (4.2):
      Built From: (Pre made SD Image)
      USB Devices connected: bleutooth adapter wifi dongel EDIMAX EW-7811Un
      Controller used: 8bitdo nes30 pro
      Everytime i shutdown the sytem and reboot it after a few days my wifi won't connect. I use a NESPi case.
      When i reboot the system once connected i stay connected.
      My first startup is Kodi.
      • chipsnblipC
        chipsnblip
        how far away is the pi from the wifi source, and what, if anything is between them? signal strenght might be too low to keep it alive. i had the same issue before changing the channel & boosting the wi-fi signal in my router configuration.
          cyperghost
          @Sander2506
          I think it's a powersaver issue caused by this wifi plug
          https://www.raspberrypi.org/forums/viewtopic.php?t=61665
            Sander2506 @cyperghost
            @cyperghost thnx, i Will try iT.
