    Scummvm controller help
    scummvmcontroller help
    76 Posts 8 Posters 13.5k Views
      bassman6805
      Sorry about that. Will this still work at the opening scummvm screen? That's as far as I can get. I don't have any games loaded because I can't move the cursor to load them. This is all I get.
      • ExarKunIvE
        ExarKunIv @bassman6805
        @bassman6805
        yes if you put this in the ssh it will come up with something
        then
        sudo killall > /dev/null 2>&1 xboxdrv
        sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv    \
        --evdev /dev/input/event0 \
        --silent \
        --detach-kernel-driver \
        --force-feedback \
        --deadzone-trigger 15% \
        --deadzone 4000 \
        --mimic-xpad \
        --evdev-keymap KEY_#44=a,KEY_#45=b,KEY_#31=x,KEY_#30=y,KEY_#16=lb,KEY_#17=rb,KEY_#1=back,KEY_#28=start,KEY_#108=du,KEY_#106=dr,KEY_#103=dd,KEY_#105=dl \
        --ui-buttonmap b=BTN_LEFT,a=BTN_RIGHT,start=KEY_F5,dr=REL_X:25,dl=REL_X:-25,dd=REL_Y:25,du=REL_Y:-25 \
        --ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
        if all works then this will come up as soon as you hit enter
        xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
        Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
        Licensed under GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
        This program comes with ABSOLUTELY NO WARRANTY.
        This is free software, and you are welcome to redistribute it under certain
        conditions; see the file COPYING for details.
        Your Xbox/Xbox360 controller should now be available as:
          /dev/input/js1
          /dev/input/event2
        Press Ctrl-C to quit
          bassman6805
          Here are the results.
          This is free software, and you are welcome to redistribute it under certain conditions; see the file COPYING for details.
            /dev/input/js0
            /dev/input/event1
          After that I was able to get the directional stick to work and the buttons.  Once I restarted the unit it stopped working again.  I'm guessing something from the code needs to be added or changed.  Thanks for taking the time to help.  Looks like we or more you might be close to fixing the issue.
          • ExarKunIvE
            @bassman6805
            that is great, so the hard part is done and over with. now we just need to get it to start when you start scummvm
            so now you need to have it look like this in your runcommand-onstart.sh
            #!/bin/sh
            if [ "$1" = "scummvm" ]
            then
            sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1 \
                --evdev /dev/input/event2 \
            	--silent \
            	--force-feedback \
            	--mimic-xpad \
            	--dpad-as-button \
                    --deadzone 15% \
            	--trigger-as-button \
            of course change what needs to be changed, but the top few lines are needed to have the mapping auto start.
            post what you have in your runcommand-onstart.sh and i will take a look if it still not starting
              bassman6805
              Still no luck. Here is what I have.
              then
              --silent \
              --force-feedback \
              --deadzone 4000 \
              --mimic-xpad \
              fi
              • ExarKunIvE
                @bassman6805
                is that all that you have in the run command? if you are missing a few things
                  bassman6805
                  Yes. I just copied from guide and changed the button numbers.
                  • ExarKunIvE
                    @bassman6805
                    ok that is why it is not working. there are commands that are needed before the keymapping
                    here is the complete runcommand-onstart.sh ( of course you just replace the mapping here with the one that we got working for you)
                    #!/bin/sh
                    ## Name of the emulator
                    echo $1 >> /dev/shm/runcommand.log
                    ## Name of the software used for running the emulation
                    echo $2 >> /dev/shm/runcommand.log
                    ## Name of the rom
                    echo $3 >> /dev/shm/runcommand.log
                    ##Executed command line
                    echo $4 >> /dev/shm/runcommand.log
                    if [ "$1" = "videopac" ]
                    then
                        --evdev /dev/input/event3 \
                        --silent \
                    	--force-feedback \
                    	--mimic-xpad \
                            --deadzone 15% \
                    	--evdev-no-grab \
                    	--dpad-as-button \
                    	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                    	--evdev-keymap KEY_#304=a,KEY_#305=b,KEY_#307=x,KEY_#308=y,KEY_#312=lt,KEY_#313=rt,KEY_#310=lb,KEY_#311=rb,KEY_#317=tl,KEY_#318=tr,KEY_#314=back,KEY_#315=start \
                    	--axismap -Y1=Y1,-Y2=Y2 \
                            --ui-buttonmap a=KEY_UNKNOWN,b=KEY_UNKNOWN,start=KEY_UNKNOWN,back=KEY_UNKNOWN,x=KEY_UNKNOWN,y=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN \
                    	--ui-axismap x2=KEY_#2:KEY_2,Y2=KEY_3:KEY_4 \
                    fi
                    and the runcommand-onend.sh
                    #!/bin/sh
                    sudo killall >/dev/null xboxdrv
                    sudo pkill -CONT python
                      bassman6805
                      I'm really confused now with the runcommand-onend.sh. Here is what I have for the onstart.
                      ## Name of the rom
                      then
                      --silent \
                      --force-feedback \
                      --deadzone 4000 \
                      --mimic-xpad \
                      fi
                        bassman6805
                        Here is the onend.sh
                          --evdev /dev/input/by-id/event2 \
                          --silent \
                          --force-feedback \
                          --deadzone 4000 \
                          --mimic-xpad \
                          --evdev-absmap ABS_[•]=x1,ABS_[•]=y1,ABS_[•]=x2,ABS_[•]=y2,ABS_[•]=lt,ABS_[•]=rt,ABS_[•]=dpad_x,ABS_[•]=dpad_y \
                        • ExarKunIvE
                          ExarKunIv
                          @bassman6805
                          Yoy just need the first two lines for the on end
                          Just copy what I posted on my last post. That is all you need
                            bassman6805
                            Still no luck. Here is my onstart setup.
                            ##!/bin/sh
                            ## Name of the rom
                            then
                            --silent \
                            --force-feedback \
                            --deadzone 4000 \
                            --mimic-xpad \
                            fi
                            Here are my onend settings.
                            #!/bin/sh
                            I'm not sure why it's not working now.
                            • ExarKunIvE
                              @bassman6805
                              is your controller event 2 or 0 ?
                              your earier post when you ran cat /proc/bus/input/devicesit came up with event 0
                                bassman6805
                                It's probably event 0. I think I copied the text from one of the reply's and didn't change it. I thought it was supposed to be event 2. I will try it when I get home.
                                  bassman6805
                                  I changed it back to event0 but still not working. I have tried event0, event1, and event2. I'm so confused.
                                  • ExarKunIvE
                                    @bassman6805
                                    that makes two of us.
                                    just one quick question where do you have the runcommand files placed in your pie?
                                    try this
                                    To fully round out this section on key-mapping, it should be mentioned that in some scenarios, the keyboard that xbmc virtualizes may not be recognized as being a keyboard by the software you intend to use it with. In this situation, you can create a udev rule that will authenticate the input as being from an actual keyboard at a system level, allowing it to function anywhere. To add this udev rule, drop to the command line and type:
                                    sudo nano /etc/udev/rules.d/99-xboxdrv.rules
                                    Press 'Enter" and type the following:
                                    SUBSYSTEM=="input", ATTRS{name}=="Microsoft X-Box 360 pad", GROUP="users", MODE="0666", ENV{ID_INPUT_KEYBOARD}="1"
                                    Now press 'ctrl+o' to save the file, 'Enter' to confirm and 'ctrl+x' to exit.
                                    if that dont work then we need to view the log file to see why
                                    you will have to use WinSCP to dive into your Pie and view the /dev.shm/runcommand.log there.
                                    other then that i done know. from my end you have everything set correctly
                                      bassman6805
                                      The xboxdrv.rules was already present. The runcommand files are located in opt/retropie/config/all. Here is a pic of all the files in the folder.
                                      I can't find a runcommand.log file. I have searched the whole system. Where would I find the file?
                                        bassman6805
                                        Here is a rundown of everything I have so far just to make sure something isn't messed up.
                                         I: Bus=0003 Vendor=0001 Product=0001 Version=0001
                                        N: Name="retrogame"
                                        P: Phys=
                                        S: Sysfs=/devices/virtual/input/input0
                                        U: Uniq=
                                        H: Handlers=kbd event0
                                        B: PROP=0
                                        B: EV=3
                                        B: KEY=1680 0 3000 d0030002
                                        evtest /dev/input/event0
                                        Input driver version is 1.0.1
                                        Input device ID: bus 0x3 vendor 0x1 product 0x1 version 0x1
                                        Input device name: "retrogame"
                                        Supported events:
                                          Event type 0 (EV_SYN)
                                          Event type 1 (EV_KEY)
                                            Event code 1 (KEY_ESC)
                                            Event code 16 (KEY_Q)
                                            Event code 17 (KEY_W)
                                            Event code 28 (KEY_ENTER)
                                            Event code 30 (KEY_A)
                                            Event code 31 (KEY_S)
                                            Event code 44 (KEY_Z)
                                            Event code 45 (KEY_X)
                                            Event code 103 (KEY_UP)
                                            Event code 105 (KEY_LEFT)
                                            Event code 106 (KEY_RIGHT)
                                            Event code 108 (KEY_DOWN)
                                        Properties:
                                        Testing ... (interrupt to exit)
                                        nano /opt/retropie/configs/all/runcommand-onstart.sh
                                        ##!/bin/sh
                                        ## Name of the rom
                                        then
                                        --silent \
                                        --force-feedback \
                                        --deadzone 4000 \
                                        --mimic-xpad \
                                        fi
                                        nano /opt/retropie/configs/all/runcommand-onend.sh
                                        #!/bin/sh
                                        • ExarKunIvE
                                          @bassman6805
                                          everything else looks like it should
                                          did you run this ?
                                          chmod +x /opt/retropie/configs/all/runcommand-onstart.sh
                                          and
                                          chmod +x /opt/retropie/configs/all/runcommand-onend.sh
                                            bassman6805
                                            Yes, I ran those when I very first created the runonstart and runonend files. I did that following the guide. I am idiot when it comes to linux. The part that gets me is when I started scummvm and remoted into it and run the command you gave me it started working. If you can tell me how to find the log file I will post it.
