    NESPi case, trying to hack in a Mausberry, may have destroyed it, help!
    nespi caseraspberry pi 3mausberry
    39 Posts 7 Posters 10.4k Views
    • lostlessL
      lostless @jmcfsu13
      @jmcfsu13 I used a 200ohm resistor on the LED. A basic red LED drops 1.7 - 2.0 volts and max current of 18-20mA. So giving it 3.3V minus the 1.7 leaves 1.6 volts to be used by the resistor.. We want 18mA max. In don’t know the specs of this individual led. So ohms law. 1.6/0.018 = 88.8 ohms. So 100ohms is the closest and an extra 100 to lower brightness a tad if even noticeable.. LED don’t dim in a lineier fashion and i’ve ran them in the microamps with it still being visible.
        jmcfsu13 @lostless
        @lostless cool, can you explain the two resistors on the reset button and how you came to those values? You seem to really know your stuff.
        • lostlessL
          lostless @jmcfsu13
          @jmcfsu13 it’s just a voltage divider. The 2 are a 10k ohm and 1k ohm. It’s 10k from 3.3v to gpio and one side of switch. 1k from other side of switch to ground. With the reset open, the 10k really does nothing. It does help lower the current going to the gpio pin. But it’s virtually 0 if set up right. From what I undersatnd, Gpio pins are basically look like and open circuit when set as a input with pull up tuned on. It’s just measuring what voltage there is on the pin. That’s it. So with the switch open, it just reads 3.3 ish volts. A high. When the reset is pushed the 3.3 v now has a route to ground through the second resistor. From there the gpio is measuring the voltage from ground across the 1k. Since the 10k is ten times greater than 1k. So the 10k drops 10 times more voltage than the 1k.
          Formula 3.3v = x + 10x. X being the voltage at the 1k
          So the point between the Two resistors is 0.3v. The pi low point triggers around 1.1v. So the pin reads low. The large nubers are there just to keep current down. Ohms law again. 3.3/(10k+1k)= 0.3mA or 300 microamps, is pulled when the button is pressed. Gpio cares nothing about current as an input.
          Ohms law
          E=I*R
          E measured in volts
          I measured in amps
          R measured in ohms
            day @lostless
            @lostless thanks a lot for these pictures and explanation. Helps a lot. Will give it a try tonight. Quick qsts however, I don't see the 'reset resistors' you just explained, in fact I don't see the reset switch wired to anything and nothing from RST on mausberry PCB, why? Also, I should cut something in the PCB that is top right in the second picture, right? And finally, white and blue wires from mausberry goes to gpio23 and 24 of pi without resistors, right?
            Best,
            day
              jmcfsu13 @day
              @day do not cut the pcb! That was a mistake by the guy who started the thread. If it Doesn't fit cut a notch in the screw hole to make room.
              D cyperghostC 2 Replies Last reply Reply Quote 0
                day @jmcfsu13
                @jmcfsu13 sorry I meant red and black wires in the switch PCB not the mausberry PCB itself.
                • lostlessL
                  lostless @day
                  @day he’s probably looked at my post on this other thread. https://retropie.org.uk/forum/topic/13361/yet-annother-retroflag-nespi-case-with-mausberry-softshutdown-duo-led-momentary-switches/
                    cyperghost @caver01
                    @caver01 said in NESPi case, trying to hack in a Mausberry, may have destroyed it, help!:
                    @cyperghost I am thinking I need to get one of these cases for my next project, but I don't see why you'd have to cut any traces or even replace the power PCB. Can't you simply follow the traces to the built-in header block and add your wiring there instead of using the stock plugs?
                    Yes... buy one! It's really a nice case and worth the money but don't spend more than 20-25$
                    About the switches. There are two of them a momentary (the reset switch) and a permanent (the power button). If you don't cut the traces then 2 working power switch that can be used like a momentary or a permanent buttons.
                    So I think it's better to cut the traces and make use of two seperate buttons. But as the mausberry is working better momentary buttons (think about software shutdown) - I rebuild the whole PCB with two momentary units ;)
                    Seems like even the Mausberry circuit could nestle in next to the existing power board and you could just run the power wires over to it or solder on a micro USB plug. Maybe the space constrains are too tight? I think I would have to give it a try.
                    Surly the MB fits next to the orginial power input. But then you have to solder directly on the Mausberry without proper pads. Surly it works but I don't like it that way and would always prefer soldering lugs.
                    I removed the old power unit and dremeled down the old holders. Made a small cut in the column (the first poster here should better do that) and used some small plastic rows as holders fixed with super glue.
                      cyperghost @jmcfsu13
                      @jmcfsu13 With cut the traces I ment the traces on the switch PCB not the Mausberry device!
                      Like @lostless wrote you can see the two ways of building this in the thread here
                      @lostless cutted the traces of the orginial NESPi buttons
                      @cyperghost rebuilded the NESPi switch PCB
                      • caver01C
                        caver01 @cyperghost
                        @cyperghost said in NESPi case, trying to hack in a Mausberry, may have destroyed it, help!:
                        I guess I am looking at that switch PCB and to me it looks like those traces just lead to a little white connector block. Why not just unplug the connector there and tap into the switches using the existing block? The Mausberry I have works with either momentary or regular on/off switches--according to the maker/vendor it auto-detects whichever you decide to use.
                        I was not thinking of soldering the power directly to the Mausberry, but sticking a micro USB connector on the end and just plugging it in, effectively using the existing power PCB as a mounted port--a passthrough to the mausberry circuit. I think my mausberry circuit is smaller than yours--maybe half the size.
                        I will have to pick up one of these cases on my own and do a few tests. In the end, It's cheap enough to just modify it by dremeling the post and cutting traces, but I was thinking there were non-desctructive ways to do it.
                          cyperghost @caver01
                          @caver01 Sorry for my bad english
                          The original state of the power and reset switch do exactly the same. They just cut the power.
                          The original NESPi switch PCB has 6 cabels.
                          2 for feed in power from the power connector
                          2 for feed USB Hubs of NESPi case
                          2 for the switches...
                          So the reset and the power button are doing the same action... They are just cutting power. So you have to cut the traces or rebuild the PCB.
                          The mausberry I used is ~ 22x33mm
                          Of course you can use the orginal power inlet - I considered in doing this, too. But it was easier in preparing the way I did, because you have always to mount the PCB in a fix place and imho it doesn't matter to take the time to do an exact job to fit to the connector hole or just to mount it somewhere :)
                          But as I said ... get that case ... it's really a pleasure to work with it.
                          Imho the @petrockblog Powerblock is the best power switch for this usecase
                            day @cyperghost
                            I'm gonna go with @lostless solution and cut the traces as I understand how to get to this point:
                            ok
                            however I dont get how to reach this image :
                            I circled in red a black wire, a yellow wire and a resistor and I am not sure to where should it be wired...I suppose somewhere to the reset switch.
                            Also I only see one resistor, and not two like mentionned previously bw jmcfsu13.
                            And finally, at the left on my red circle, there are two wires that are cut, right ?
                            • lostlessL
                              lostless @day
                              @day the wires are cut. They went to the mauseberry input.
                              The yellow is heat shrink tubing, to prevent a short with a gpio pin. with a resistor underneath. It’s a 10k ohm going from the reset button to the .3.3v line. Then there’s a wire going from that same location to then gpio pin. Pin 33 to be exact. Then there’s a 1k going from then center tap of the switch to ground. That’s the voltage divider.
                              A schematic of the divider.
                              That circuit right there does nothing unless you program it to do somthing. https://retropie.org.uk/forum/topic/13141/gpio-button-to-exit-emulator
                              Where I discuss programming it. It was working until last retropie update. So trying to figure that out.
                                day @lostless
                                @lostless oh now I got it better ! the color was confusing me, now I see the wires indeed...ok so this is for a certain purpose that you are developping in the thread you just mentionned, its not to have the reset switch do the reset feature then, and it is not mandatory.
                                which is in fact a good thing since having a real reset would be opposite goal of what we are doing since it wont be a safeshutdown....
                                very clear now, thanks a lot !! will definitly give it a try tmrw and try to have fun with it !
                                • lostlessL
                                  lostless @day
                                  @day I originally programed it to exit any programs and go back to emulation station like the real nes mini exits back to its main menu. Its stopped working after I updated last night, so figuring that out. But it can be set to do anything if you know what you're doing.
                                    day @lostless
                                    @lostless which script are you using for the Shutdown part? Mausberry 's?
                                    • lostlessL
                                      lostless @day
                                      @day im going to continue this conversation on this thread. ill have the script an script for reset there. https://retropie.org.uk/forum/topic/13361/yet-annother-retroflag-nespi-case-with-mausberry-softshutdown-duo-led-momentary-switches/24
                                        day @lostless
                                        @lostless I managed to wire the on/off switch like you said (cutting the traces) and add mausberry script and it is working smoothly and perfectly !!! thank you again and again !!! I put the reset button part on hold, the time for me to understand what to do with all the scripts you just posted, but i will continue on the other thread.
                                        • demesauceD
                                          demesauce Banned
                                          How about you use the reset on the Raspberry Pi itself?
