    PPSSPP installation error "Could not successfully build lr-ppsspp .... ppsspp_libretro.so not found)
    ppsspp
    7 Posts 4 Posters 2.0k Views
      DasTronkh
      Hello Guys. I have trouble installing either the normal ppsspp emulator or the libretro version. The setup always stops at the same spot with the same error: " Could not successfully build lr-ppsspp - PlayStation Portable emu - PPSSPP port for libretro (/home/Micha/Retropie-Setup/tmp/build/lr-ppsspp/libretro/ppsspp_libretro.so not found)". I installed other packages like lidesmume without problems its just the psp ones. Error Log: link text
        DasTronkh @DasTronkh
        The error above came from the libretro ppsspp package i now ran the normal ppsspp another time because it has a different error: "Could not successfully build ppsspp - PlayStation Portable emulator PPSSPP (/home/Micha/Retropie-Setup/tmp/build/ppsspp/ppsspp/PPSSPPSDL not found)" again some file is missing. Error Log link text
          DasTronkh
          ~ Solution found ~
            diptherio
            @dastronkh Care to share it with the rest of us? I'm having this same problem. Thanks.
              mitu Global Moderator @diptherio
              @diptherio Care to explain your error ? The original poster was trying to install on Ubuntu or other supported x86 distro, but you haven't given any information about yours - is it a RPI or a pc ?
                diptherio @mitu
                @mitu Thanks for the response. My issue is exactly the same as the posters. Attempting to install the lr-ppsspp emulator on a PC running Ubuntu MATE and receiving the same error message as the poster. I've done this successfully on another machine with the same OS, so I'm a bit confused.
                  BuZz administrators @diptherio
                  @diptherio Start a new topic after reading https://retropie.org.uk/forum/topic/3/read-this-first and providing the required information. (provide a build log also).
