    Wireless controllers that work best?
    controllers
    41 Posts 26 Posters 46.2k Views
    • maxbeanzM
      maxbeanz @Ecks
      @ecks said in Wireless controllers that work best?:
      GameSir G3s/G4s are the best controllers i have used on my Pi.
      The Gamesir G3s is terrible. Yes the controller feels great but I couldn't get it pair with Bluetooth with D-Input or X-Input and if you use the wireless dongle it randomly disconnects and you either have to unplug the dongle or reset the Pi before you can connect again. Apparently it's a known problem and they offered to send me a G4s instead. I got a refund. 8-bitdon't are releasing a new controller on December 10th, SF30 Pro. This time a decent size with dual analogue sticks. £35 though.
      • EcksE
        Ecks
        @maxbeanz There is something wrong with your unit then because i use it by the dongle and never had disconnection issues at all with my controllers and i use the G3s and G4s on my unit.
        • retroprogrammerR
          retroprogrammer
          Ps4 controllers are pretty easy to setup I recommend this
          Here is me converting the original Xbox for a case:
          https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
          Check out my GitHub: https://github.com/retro-programmer
          • E
            EctoOne
            I was using a PS3 when I got my Pi but I never liked the controller, it's too small and since I used a GameCube controller I have a hard time going back to the PS controller layout (left stick at the bottom), so I got me a Logitech F710 because it is mentioned in the wiki and I can't complain. Plug and play, and I like that I can switch between analog and digital control with a button press.
            • spruce_m00seS
              spruce_m00se @blitzgreig
              @blitzgreig Do you still need to instal ds4drv in order for it to work? perhaps you have a different revision of the controller because for me it simply didnt work without ds4drv.
              EcksE 1 Reply Last reply Reply Quote 0
              • EcksE
                Ecks @spruce_m00se
                @spruce_m00se said in Wireless controllers that work best?:
                If you updated your PS4 controller with the new update for it you should be able to connect it by bluetooth without any problems.
                1 1 Reply Last reply Reply Quote 0
                • RichardBrR
                  RichardBr
                  I second Xbox 360 wireless controller. Easy to set up and works ok. And it has reasonable price, on Amazon it's around $30
                  https://www.amazon.com/Kycola-Controller-Wireless-Gamepad-Black/dp/B075Q5C6KR/ref=sr_1_1_sspa?s=videogames&ie=UTF8&qid=1511519210&sr=1-1-spons&keywords=Xbox+360+Wireless+Controller&psc=1
                  It is the greatest of all mistakes to do nothing because you can do only a little. Do what you can.
                  Sydney Smith
                  • 1
                    172pilot @Ecks
                    @ecks How do you update a PS4 with the new update? Do I need a PS4 to do so?
                      RetroFreak89
                      That Logitech wireless one i heard was good Its the new bluetooth..
                      Also but why wireless? Emulation already has input delay So if you use wireless then theres a small delay again ontop of that idk i like to use wired with emulation just to get the best input speeds
                      For game like mega man,Mario,and even dls like doom input means alot
                      • herb_fargusH
                        herb_fargus administrators @RetroFreak89
                        @retrofreak89 Logitech doesn't use Bluetooth, it uses a proprietary 2.4 GHz frequency.
                          MosEisley1976
                          I am new to this and would like to use xbox 360 controllers as I have them but I have a look for the Zetta Guard dongle but could not see it for sale in UK are there any other options or what cheap wireless controllers are there
                            jonceramic @MosEisley1976
                            @moseisley1976 There are generic xbox 360 usb receivers sold on aliexpress and ebay that work just great out of the box. If you search for "xbox 360 receiver", you'll find so many your eyes will cross. Most are around $8-9 USD. They come with tiny driver CD's, but you don't need them. They work plug and play with retropie, with a free driver on MacOSX, or, if you follow the writeups on the web, natively in Windows10.
                              jonceramic @jonceramic
                              @jonceramic I just googled ZettaGuard, and it's a "Brand" name of the same generics sold all over...
                              • U
                                urukai @BladeHunter
                                @bladehunter I'm maybe late, but I have 5 PS3 controllers and I encounter the same issue with both of them ...
                                Never find a real solution with these controllers. (use embeded BT chipset of the RPi, different dongles, different drivers, disable the BT chipset of the RPi, Run a bunch of command lines and reinstall a 100 time, Etc. with the the same results.
                                I tried a 2.4GHz controller, there is less lag, but I think the best is unfortunatly a hard-wired controller :s > I also use USB cards adapters for Sanwa sticks, and there, I have no lag.
                                If you have found a real and simple solution for the PS3 controllers ... :)
                                  Kookamunga @BladeHunter
                                  @bladehunter I had similar issues when connecting more than one controller to the RPI3's built in bluetooth. I ended up using an old USB Bluetooth 2.1 + EDR dongle I had, disabled the integrated bluetooth, and it seems to work pretty good. I can't say how much lag there is, but it's good enough to be really playable. I tried a Bluetooh 4.0 dongle I bought off Ali Express, but I couldn't get more than 2 controllers connected at a time.
                                  I have a NESPi case, and I connected the dongle directly to one of the ports within the case, that way it isn't visible, and also to reduce any potential issues that may be caused by plugging into the front usb ports the case comes with.
                                    @bladehunter I also run most of my cores at 640x480 resolution to reduce the amount of stress on the Pi, which may in turn also reduce input lag. Couple that with the HQScale 2x shader, and it still looks pretty good. That being said, you may want to take any shaders you might be using into account, as in my opinion, that may add to the input lag, as it's one more thing that the Pi has to take into account before presenting your game and all it's inputs. Best scenario is shaderless, but for me that's hard to look at on a 50" LCD screen.
                                      CapNinja
                                      I have a ps4 controller and it works great. Except on Beat'em Ups or Fighting games. In these cases The input lag keep pilling up to the point I can't even dash anymore.
                                      But, it is good? Yes it is.
                                        mulder79
                                        From what i have read the PS3 pads worked well with the Pi3 but i would like to know how many controllers can I use at once ? that is by connected directly with bluetooth
                                          Kookamunga @mulder79
                                          @mulder79 I've used up to 4 controllers with the built in Bluetooth of a Pi 3B, but for some reason I noticed some input lag as more controllers were added, but your mileage may vary. It could have been related to power issues that my case had, but I've since hooked up a Bluetooth 2.1 +EDR USB adapter and I can run 4 PS3 controllers without any noticeable issues. I've also tried a cheap Bluetooth 4.0 adapter I ordered from Aliexpress, but it only wanted to run 2 controllers. It wouldn't even allow more to connect.
                                          So you may have some success with at least 4 PS3 controllers with the built in bluetooth.
                                          • EcksE
                                            Ecks
                                            As of right now i am using 3 SN/SF30 Pro controllers and i hardly notice any input lag and also for fighting games i find it works better than using a PS3/PS4 controller.
