    MAME Control Panel Issue
    control issueusb controlersmame
    2 Posts 2 Posters 659 Views
      spicysupport
      Hi,
      I have installed Retropie on a Raspberry Pi 3 with Attract mode.
      I have a USB Encoder which allows me to connect arcade buttons and joysticks to it.
      I can use the arcade buttons and joystick to navigate Attract mode with no issues..
      When I launch a mame game, i'm pressing tab on my keyboard to get into the mame config.
      My issue is when i'm in mame config and trying to assign the control's / buttons it does not recommend the commands from my buttons or joystick.
      Can someone please help!
      Phil
      • rbakerR
        rbaker @spicysupport
        @spicysupport You aren't really supplying enough information for help to be possible. You don't even say what encoder it is. To begin the process of support, please follow this:
