    NES RessurctionXtras 2.0 Project (thread previously titled: Does anybody work on Emulators to fix broken games here?)
    nescompatibility
    150 Posts 14 Posters 24.5k Views
    • Used2BeRXU
      Used2BeRX @A Former User
      @livefastcyyoung Ah... thanks. Makes sense. I figured they must be important. Most NES games don't have a battery, but doing my suggestion would break the ones that did then.
      • Used2BeRXU
        Used2BeRX
        Just recently added "Bio Hazard" to the NES Translated library, thanks to packnsacdave at romhacking! Bio Hazard was a Waixing Pirate back-port of the original PSX Resident Evil for the Famicom that was previously only in Chinese.
        It worked with no issues on lr-fceumm, and I've recently gotten confirmation that it is now working in NestopiaX on the XBox! (If anybody would be interested in getting it working in lr-nestopia, I'm sure I could get the info on how to get it working in Nestopia).
        Here's some info on it: http://bootleggames.wikia.com/wiki/Bio_Hazard_(Famicom)
        I took the image from that page of the box, cart and manual and I made Boxart and Cart art for everyone.
        Used2BeRXU 1 Reply Last reply Reply Quote 1
        • Used2BeRXU
          Used2BeRX @Used2BeRX
          Untranslated FDS Games: 65 out of 66 working.
          FDS Hacks: 2 out of 2 working.
          Druid is the only game that doesn't work. The info part of the screen flickers so bad you can't play it at all in either emulator. Hopefully this can be fixed since it is a cool little game.
          Fortunately all working games play just fine in lr-nestopia. This means the only FDS games that currently need lr-fceumm are the translations of "19 Neunzehn" and "Lutter".
          Adult Games tested: 28 of 28 work. All FDS games in this category work in lr-nestopia, but it's better to use lr-fceumm for BodyConQuest because it is the only 2 Disk FDS game and the disk flip function will not work on it. You need to load 1 of 4 disk sides.
          Well... that's it for the FDS testing. I will have to try to get in contact with somebody who can fix the 5 or 6 games out of around 2,020 games that don't work on the RetroPie. Overall, I'm very impressed with the NES/FDS compatibility here. Nice job. :)
          Used2BeRXU 1 Reply Last reply Reply Quote 0
          • Used2BeRXU
            Unfortunately, because of the nature of the cart images and my inability to properly crop them without damaging the shape of the case, there will be absolutely no way for me to easily do this for that type of image.
            What this means is a few things....
            First, I'm going to have to make that part of the collection much larger in file size by converting them all to PNG, rather than JPG images. (From the looks of it, we can expect the 'Cart' folder to grow in file size by around 5 times). I don't yet know if this will effect how large an image I can use on both the XBox and RetroPie without impacting performance (Maybe somebody here who knows that can chime in on the issue???)
            Second, is that although the final pixel sizes will be perfect ratios with transparent backgrounds filling them out, I won't be able to have perfectly sized carts relative to each other. It's just impossible without force altering the ratio of the image which will degrade quality. In actuality, this shouldn't be that big a deal because we're really only talking about the difference of a few pixels on the Right Side or the Bottom of the image that will be transparent to fill the image out. In any case, the slightly different size of some carts will be much less noticeable than grainy images by forcing ratios on them.
            Third, this is a TON more work (and Math) for me to do and it will likely be a very long time before I'm finished with this. I've also decided since I will already be forced to use PNG images and I'm going to be using transparency anyhow, that I will also take the time to remove the non-cart parts of the images, such as the "holes" at the bottom right and left of a US/PAL NES cart image. This will give us full transparency of all of the cart images. I'm not sure how beneficial this will be in the Madmab/XBox emulators, but on the RetroPie it will look amazing as the images will just float over the skin background and will now look as though the cart is just floating there instead of a photograph of a cart with the background shadows behind it.
            I REALLY wish I knew this was going to be the case before I had done other work, such as creating all of those FDS images from a template with the individual game labels. I'm going to end up just re-doing all of them on a single fixed template and wasting 2 full nights of work on it rather than 2 weeks trying to crop all the background noise for each individual image.
            Oh well....
            I don't think we're going to have any problems with the Box images still. I won't know until I get to them.
            • Used2BeRXU
              I don't think there's any great way of displaying what I've been doing with the cart images in a forum, but if you were to download the two of these and open them in a good image program you could see how these are now transparent.
              New Image:
              Original Image:
              I got about 100 of these done so far.
              I'm also making them centered in the image, as every single new image will be a ratio match of any single other image without actually changing the shape of the image by forcing a ratio and blurring the image. In my tests so far, it looks like this will work great with mass-resizing to the desired thresholds for performance on different systems.
              EDIT: If you click on both images they will open in new tabs. You could flip back and forth between the two of them and see the difference. The new image has a transparent border around it as well as the two black spaces at the bottom are now replaced with a transparent border. In the image in your browser it may seem that this is all "white", but in actuality if you were to have this on your RetorPIe the white border would show whatever was behind the image on the skin. :)
              • Used2BeRXU
                Small update to anybody who's following....
                I've done all the Licensed US games that weren't light gun or power pad so far, as well as all game hacks in the collection that used those games.
                I'm now working on the Unlicensed US game carts, which is proving to be a lot more difficult, due to the fact there were so many different types of carts and the images are not standardized. This will be the same issue when I get to the pirated NES/Famicom carts as well, but fortunately the Japan cart collection is almost completely standardized like the US set was, so that should go fairly quickly again when I get to the Translations and Japan Licensed carts. Same for the EU licensed carts.
                If I had to guess, I've got about 900 of the 2,000+ carts done so far. Fortunately, doing the box art will be infinately easier than this is. I will probably be able to do a mass crop, if I can figure out how to set the parameters for it, and then I can just go through manually and re-do any that didn't work by hand.
                Here's a few more samples:
                Used2BeRXU lilbudL 2 Replies Last reply Reply Quote 0
                • Used2BeRXU
                  Color Dreams carts... what a monster... Unlike all of the other Licensed and Unlicensed carts I had, they are not aligned properly. Because of the lower quality (around 600x668 pixels), any "tricks" I tried would degrade the quality of the image.
                  My fix was to find a very large color dreams cart, fix the aspect ratio and perspective and make a template. Here it is:
                  With that, I was able to re-make a cart of Chiller by taking the label off the best image I could find for the cart:
                  I think it looks pretty sweet. What do you think?
                    lilbud @Used2BeRX
                    @used2berx If you look on the frontpage of www.thecoverproject.net, someone redid all the nes games box art.
                    • Used2BeRXU
                      Used2BeRX @lilbud
                      @lilbud I'll take a look at them, but they seem smaller than the ones that I have. Most of my official ones are anywhere from 1,200 to 1,500 pixels tall, and there are over 2,000 of them overall, not just the 750 or so official US releases.
                      I didn't have to fix any of these large images, since the place I got them from already had them fully restored at this size. I did restore hundreds of Japanese and China pirate covers though, and I will be replacing many of them with covers that @darknior made since he's an actual graphic artist and I'm just a weekend warrior when it comes to that stuff.
                      There may be a few in there that could replace some that I've got though. Thanks.
                      • chipsnblipC
                        chipsnblip
                        great work on this project so far, been keeping an eye on it for a while. your dedication is inpiring @Used2BeRX!
                        the full images are much larger, for example Mach Rider is 3431x2100 weighing in @ 5.2 MB. i had to enable javascript to get to the mediafire download though (ugh)
                        • Used2BeRXU
                          Used2BeRX @chipsnblip
                          @chipsnblip said in NES RessurctionXtras 2.0 Project (thread previously titled: Does anybody work on Emulators to fix broken games here?):
                          Thanks man. :)
                          I've been at work on the Pi since around May of last year when my brother gave me one of the Pi Zero's he bought to make for two of his in-laws. It was supposed to be a quick job just getting the games to actually work so he could put them in NES carts and give them as gifts before the end of summer for the kids to play. Then it was supposed to be Christmas presents. I've promised him that they'll at least get it by this summer time. lol.... I really hope I can deliver on that.
                          By around August, I started working on NES exclusively. This is upgrading a set that I worked on with many, many other people with for the XBox mod community around 10-12 years ago, but I felt we had spread ourselves far too thin tackling too many systems at once, and in the end it was hard to keep everyone on the same page, so quality varied in nearly every aspect. It was just such a monstrous challenge. I felt we did a really great job at the end, and everyone I had given an XBox to afterward was amazed by it, but I always felt it could have been better.
                          So now I'm just taking it as slow as it need to be and doing it on my own to ensure everything is done in a uniform fashion. As I've gone along I've even decided to do things that have never occurred to me in the first place. Making these transparent cartridge images is an example of that. Had I not needed to make them PNG images to make the background transparent in order to preserve their aspect ratio for the inevitable resizing, I wouldn't have decided to go the extra mile and really make them shine by making them have completely transparent backgrounds. They really look amazing when you're scrolling through hundreds of them. I'm hoping I can convince the guys running retro-pie to add more image tags such as <cart>, <boxfront>, <title> and <action> for anybody who wanted to really take advantage of my work when it's complete.
                          Yes, I see. I misread when I glanced at the page the first time and saw the 600dpi request and for some reason thought the images were 600 pixels. (Forgive me for that guys, as well as my lack of replying until now... I've been deathly ill for about a week. I even missed a few days of work and had my first 3 days off in about 2 months and spent them sleeping... :( )
                          The funny thing is, the place that I got my cover images must have gotten them from The Cover Project, and then just haphazardly cut the box front out of them. All of them were 2,100 pixels tall, but they ranged from 1,524 to 1,548 for width. I always found that pretty odd that the height was the same for 99% of them, but the width always varied. Now I can get the original images and re-crop them myself for a uniform size rather than further cutting down the larger ones to match the ones that were cropped too much.
                          Now I also know who to talk to for their blessing on using these images. I knew the site I had gotten them from didn't actually get them directly from the reproduction (guy, girl, team?) that made them all.
                          Although I will be looking into crowd funding for future work (and hence, not offering any roms at any time in these collections), I'm hoping that anybody who has provided any of the building blocks for the final creations I make will give their blessing in return for the much larger scope of what they will be getting back in the other aspects of the project. This will be the definitive NES collection when it is done, and nothing that exists will come close to it. I will not be holding any of the work for ransom, and I do hope that once a set is released that the big sites out there all end up using what's in it.
                          I haven't decided exactly how I'm going to go about this all just yet, but what I'm considering is getting any patreon/kickstarter stuff in place, making any low production crap video I might need to make since I have ancient tech and no film school knowledge, and then just releasing my entire NES work which will at that point have probably taken over a year of my free time to complete as a proof of concept of a much larger goal and letting it speak for itself at that point.
                          I'm thinking that legally speaking I should be shielded since I won't be providing any actual roms... and especially since I will jump right out of the gates giving the whole damn thing away for free in the first place. It's all stuff that many of our beloved gaming community sites already have on display and have had, sometimes for almost decades now... albiet in much higher and consistent quality. I look at it as I'm not selling a product, or really anything that somebody couldn't do themselves if they were insane enough to do it all on their own. I'm really just asking for people who have better stuff to do with their lives to show their appreciation for the insane amount of time and attention to detail that I give these projects for everyone else to enjoy.
                          We'll see what the future holds. I really do love working on this. I don't know how I can possibly keep working on it like I do though given my financial situation. It's already slowed down to a snail's pace since I had to finally start working again, so my free time all of the sudden has some real value to me. (Which really burns me that I've had to spend the last 4 or 5 days in bed now!!!!!)
                          Thanks for your support. :)
                          • I
                            incunabula
                            Maybe i've missed it somewhere in this thread, but are you making this collection available for download somewhere?
                            • Used2BeRXU
                              Used2BeRX @incunabula
                              @incunabula
                              Short answer: Yes, but I don't know where yet.
                              Long Answer follows....
                              Eventually I will be, when it is completed. Everything will be included except for the roms, of course.
                              I have yet to decide if I will be releasing this before or after I re-make all of the videos in HD. If you've missed my thoughts on the videos before is that although any sets out there are adaquite, there is a lot of differences in quality, length, volume and style of the video sets that are out there because too many hands were in the cookie jar. My plan is to re-make every video as well as make the first known videos for many hacks and translations, pirates, unlicensed, etc. They would all be in a standard format, and my plan would be to do them in an arcade-style "attract mode" where you get around 15-20 seconds of gameplay followed by the title-screen animation.
                              Obviously, this last part will be a massive undertaking on its own, and at this point in time I'm not even sure I have any tech in my house even capable of performing such a feat. Chances are more likely the videos would be a part II release for the NES at a later date.
                              My plan a this moment is to make 3 separate releases. One for the XBox, one for the Pi Zero and one for the Pi 3. The XBox release is pretty straightforward, but due to the much more complex nature of the RetroPie system and the necessity for the gamelist.xml to use any of the extra media, it will rely on all of the media to be in the exact location that I set on a per-system basis or else it will not work with the gamelist.xml files that I provide, that will be made using the script that the most awesome Meleu from this site has created for us.
                              For this reason, although I cannot and will not provide any roms at any point in time, I will be providing datfiles and a way to easily ensure that the roms you find on your own are all in the correct folders in as simple a process as possible. This will all take a lot of planning. Xbox makes this all easy. RetroPie makes this extremely tricky.
                              The Pi Zero set will not ever include videos since it can't handle them anyhow. It will have the lowest quality artwork. It will be the highest quality I can get away with without negatively impacting system performance which has yet to be determined.
                              The XBox will include videos, but they will need to be converted by the end user to XMV. I cannot and will not provide the XMV files because they use a proprietary M$ software. The videos will not play in any other format other than XMV which is unfortunate because not only does this at an extra step of converting, but it also requires lowering the video quality more than necessary for the specs of the machine. This will have larger artwork than the Pi Zero. I believe the specs that are considered optimal have your larger dimension somewhere between 550 to 600 pixels.
                              The Pi 3 will have the highest quality videos. Most likely in MP4, but I will be asking a lot of questions from people who know more about these things than I do before settling on any format. Artwork will be the highest quality of all 3 sets, although it still will not come close to the actual dimensions of much of the raw artwork. I've been told by people who know much more about these things that the ideal large dimension for artwork on the Pi 3 is only around 700 pixels, which is anywhere from 1/2 to only 1/3 of the size of many of the images I currently have. I've been told that they look amazing even at that size on a large 1080 screen though, so I wouldn't worry too much about it. I'm keeping the larger images in case down the road we all have 150" 4k TVs and the Pi 5 can handle them without downsizing them.
                              In the mean time, I'm not too worried about it myself. I'm doing all my work on a Pi Zero, with a rear-projection 720p TV and a 10 year old computer with 2gigs of ram that sometimes makes me think that it isn't really even up to the task of running Windows 10, what with the frequent Firefox restarts I constantly need to do to free up my memory.
                              • I
                                incunabula
                                Sounds good, i just hope you have a backup solution in your workflow.
                                • markwkiddM
                                  markwkidd
                                  Please consider synchronizing your collection to a github repository or something like that which would eventually also make it easy to distribute & incorporate into setup scripts. Even if you keep it private while it's a work in progress it might pay off in the long term.
                                  If that's something you'd consider, I'm sure there are several of us here who would help you create a githup repository. I have done a large MAME thumbnail for RetroArch and @herb_fargus has created a similarly large github thumbnail repo for RetroPie.
                                  Your project and your focus are impressive! Whatever you use for backup, thanks for sharing!
                                  • Used2BeRXU
                                    Used2BeRX @markwkidd
                                    @markwkidd
                                    Hey man. I would be thrilled if github allows for the massive amount of storage we're talking about here and somebody would work with me to get it up there. It was suggested by @meleu quite a while back and I signed up for it but couldn't figure out at all what to do with it and he's too busy to hold my hand. Consider me interested if you or somebody else would be willing to aid in this. I have way too much work on my end here to be spending tons of time trying to figure github out on my own. :)
                                    Since things aren't at a ready state just yet, most of it would not really benefit from it, but something small like the synopsis would be easy to re-up when it gets the final edits. Once I start making the full artwork size mass conversions they would start being ready as well. I doubt though that I'd ever be able to store videos there, would I?
                                    Anyhow.... the note above is actually just a small part of the overall project. It's more just what I'm working on now. I believe a more full picture of the scope of things is in the first 10 or so posts of this thread. I might just create a new thread in the near future when I'm ready to put the spreadsheet up that really illustrates what is already done and what still needs to be done.
                                    Things are backed up right now, but it's always better to have an extra one. :)
                                    markwkiddM 1 Reply Last reply Reply Quote 0
                                    • markwkiddM
                                      markwkidd @Used2BeRX
                                      @used2berx what operating system are you using on the system where you work on this project? Do you have any idea how large the collection might be when it's complete?
                                      I'll try to summarize a github workflow based on your OS/environment.
                                      The second place I would suggest keeping in mind is the Internet Archive at archive.org. I am confident that they would host this collection. Once you have a user account there you can upload through their website, plus there are other methods available to add to the archive if the content is too large to upload through the web.
                                      I'm glad to keep talking with you about this. After all the work to standardize the images themselves, hopefully it won't be too hard to find one or two solid, long-term hosts for your results.
                                      • Used2BeRXU
                                        @markwkidd I use Windows 10.
                                        I couldn't even begin to imagine how big it will be at this point. All I can say is it will be a lot smaller before the videos are made.
                                        The synopsis files are actually very small. Right now, between the games and the folders there are right around 2,050 of them, and they're all 1kb or less.
                                        Images will be all over the place since I'll have 3 sets of them with different sizes for the Boxes and Carts. The Title and Action shots will be the same for all 3 sets and will be small though. Right now, because there are 4 image types for each set at the moment, this will be about 8,080 images per set.
                                        There actually is a lot of other aspects to the project as well, but currently RetroPie is unable to take advantage of them like the XBox does. (such as manuals in either PDF format or converted to JPG and zipped up).
                                        My "plan" right now was to upload them all together somewhere, where they would need to be then downloaded and transferred over to the correct place on your Pi/XBox. That is the way it must be done regardless on the XBox, but maybe with github people could just download the thing straight to the proper location on their Pi if it were set up correctly?
                                        EDIT: When I say "right now" about the amount of images, it's because I do plan on adding more games before this is all done. I'm sure before I'm done there will be more translations since they seem to pop up every once and a while, and I still haven't really gone in and decided which hacks will make the cut. There were already a lot of them in there from ten years ago, and I only removed a few that were in some way broken. A lot of them probably wouldn't have made the cut now, but since all the work has been done for them at this point except for the videos I'm going to keep the rest. I'm sure that there are still some really great ones out there that I haven't discovered though.
                                        • markwkiddM
                                          markwkidd
                                          OK that makes sense. If you're willing to spend a little time setting up git and github (maybe 30 minutes to an hour if things go smoothly?) I think it would fit into your way of working.
                                          With git, we would designate a root folder on you PC where all of the collection lies within as subfolders. This would sync onto github as the root of your project's github repository, where among other things, it would be easy for people to script it into automated build projects like you were describing.
                                          As you continue to work on your project, you can periodically synchronize to github on whatever schedule you want. The number of files you're proposing (8,080 in this phase) is within the specs of a standard github repository.
                                          Next time you have a chance, make sure you can access your github.com account, and then see if you can create a new "repository" for your project. Once you have access to github.com I can try to help you figure out the best way to install the git client on your Windows 10 PC and designate that root folder so that it doesn't alter your organizations scheme or workflow if at all possible.
                                          • markwkiddM
                                            markwkidd
                                            Here's the libretro thumbnails repository, in fact. This would be a good reference point: https://github.com/libretro/libretro-thumbnails
