Ps4 controller input problem
I changed one of the settings in the psx menu for the controller input driver, ever since then the controller has not worked in the psx emulator but works fine everywhere else, when I use my keyboard and press F1 to rechange the setting now the select button on my keyboard doesn’t work, I have tried reconfiguring the keyboard with no luck, any ideas ?
@seffdog1 https://retropie.org.uk/forum/topic/3/read-this-first - what's your system ? Which emulator are you using ? Give us some more details about your setup to be able to help.
It seems you might have re-configured the RetroArch controller settings for the psx core, try removing the core settings from the
/opt/retropie/configs/psx/
folder.
