Emulators running slower for unknown reason
@solaris said in Emulators running slower for unknown reason:
YOu can check if it's the temperature by logging on the pi while you game using ssh and checking the temperature with this command:
The temperature is below 70 degrees on bootup, and stayed there after running some games. (They were stuttering regardless of temerature.)
You could do slight overclocking but have you tried with another microsd? Microsd going bad can sometimes load and make gameplay stutter. Happened to me a while ago. FOr the slight OC, don't overclock and CPU but you could add some memory to the GPU.
That sounds like a good test but I don't have another spare. At this point I'll probably switch to a clean install, though it would have been nice to know what went wrong. (If it's still stuttering after that I'll know it's the sd.)
Also, does it happen on demanding emulators (like n64) or even on nes and snes. Snes should have zero problems with a stock pi. If it stuters there, you might have a bigger problem.
I believe every system is affected, but it's most noticeable on the snes, gba, and psx.
@andershp said in Emulators running slower for unknown reason:
I then updated only Retroarch to 1.6.9 again (RetroPie still 4.3) and everything is terrible again. Armed Police Batrider stutters even in the menusounds.
on what emulator? mame2003? if so, that's had daily driver updates in the last few weeks and they are all untested, so who knows what's going on with that at this point.
@dankcushions I had a feeling they were not being tested but is this verified ? The libretro project is quick (too quick imho) to accept changes to cores, and in this case it seems unwise. It seems like a bad idea to submit untested backported changes to such a popular emulator.
I am considering forking and rolling back our mame2003 due to all the problems being reported.
@dankcushions said in Emulators running slower for unknown reason:
Sigh all these claims about being "untested" are plain
[removed]
every code change i've done has been fully tested on the MAME side by myself and if i broke anything
eg SEGA, Mortal Kombat sound or Batrider game speed i have fixed or attempted to fix the problems the guy should test batrider again after my recent commit
and see how it plays. -
@gamez-fan This is not a playground - watch your language and attitude unless you want to be removed.
@buzz said in Emulators running slower for unknown reason:
Right ok it's not a playground i'll watch my language, but when multiple claims are made incorrectly that i've not tested my code it's not
exactly having a bad attitude to state my case here. -
@gamez-fan It looked like that previously to me, but happy you are testing - I stand corrected. You are welcome to state your case and correct things - in a manner fitting for a public forum like this that has users of all ages etc.
Yeah fair point i'll take it on board.
In this thread I can confirm that my issues are gone after a simple .cfg file deletion and regenerating.
Please see: https://retropie.org.uk/forum/post/121812
