    Restart/Shutdown/Reboot EmulationStation options do not work after manually compiling ES from source
    emulationstatiocompilesource codesourcereboot
    11 Posts 3 Posters 4.1k Views
    • madmodder123M
      madmodder123
      So when I select "Restart EmulationStation", "Restart System", or "Shutdown System" from the EmulationStation "QUIT" menu EmulationStation closes and drops to the terminal with no error messages.
      I manually compiled ES using the following steps:
       git clone https://github.com/RetroPie/EmulationStation
       cd EmulationStation
       git checkout master
       git submodule update --init
       cmake .
       make
       sudo make install
      This issue occurs with no changes made to the source code. For some reason when I compile ES through the retropie_setup.sh script it works just fine, but when I manually compile it using the above commands the menu options listed do not function correctly.
      I tried to find the script that compiles emulationstation from source in the retropie_setup.sh script but I couldn't find it (i'm still looking for it). I was thinking I might be able to compare the commands used to compile it with the commands I used and see if there are any differences.
      I'm not sure if this is relevant but I also compiled/installed the following from source before ES was compiled:
      SDL2-2.0.7 from http://libsdl.org/release/
      https://github.com/Pulse-Eight/platform
      https://github.com/Pulse-Eight/libcec/
      Any ideas?
        BuZz administrators @madmodder123
        @madmodder123 you need to use the emulationstation.sh launch script.
        madmodder123M 1 Reply Last reply Reply Quote 0
        • madmodder123M
          madmodder123 @BuZz
          @buzz Could you please elaborate?
          I know that it is in the EmulationStation source folder, but I am not sure what you mean by using the script.
            @madmodder123 the script handles the rebooting etc. You need to launch the script not the binary directly.
            • madmodder123M
              madmodder123 @BuZz
              @buzz So would I have to place the script in the /usr/bin or the /usr/local/bin folder? I am not sure where ES gets called upon on system boot. After moving the script file would I have to edit another file that directs the OS what to launch upon boot? I am using RetroPie 4.3.7 btw.
                @madmodder123 we have another launch script for /usr/bin that launches the .sh script. This repo is designed to be used with RetroPie not manually installed. For more info on how it's launched check the RetroPie module. Why are you manually building it?
                madmodder123M 2 Replies Last reply Reply Quote 0
                • madmodder123M
                  madmodder123 @BuZz
                  @buzz I am changing the on-screen help button icons to ones that resemble the PS1 controller's buttons and changing the ES fonts used. I have them all sorted and then I ran into this issue.
                  I'll see if I can get this figured out and i'll report back here
                  • madmodder123M
                    madmodder123 @BuZz
                    @BuZz Thanks for your help
                    I got it working, I replaced the /opt/retropie/supplementary/emulationstation/emulationstation file with the one that I compiled myself. I hope this post can help someone in the future :)
                    • L
                      LionSquall @madmodder123
                      @madmodder123 can you share your edit file? i translate emulation station and i have you old problem
                      • L
                        LionSquall @LionSquall
                        @LionSquall @BuZz can help me?
                        BuZzB 1 Reply Last reply Reply Quote -1
                          BuZz administrators @LionSquall
                          @LionSquall read the sticky topics and open a new topic with info. This is a 3 year old discussion.
