    Adventures with ODROID XU4 and RetroPie
    odroid xu4bugsworkarounds
    36 Posts 8 Posters 9.1k Views
      TillmanZ @zerojay
      @zerojay Hi there!
      I was wondering if you also encountered the lvl0 failed to get mixer ALSA issue after you have installed Retropie on your XU4 with kernel 4.14.
      It is not really a critical issue for me as sound works in the snap videos and also in all the emulators but it sure looks not so very polished seeing this error appear in ES when switching the systems.
      Any idea how to fix this?
      Best,
      Tillman
      • Z
        zerojay
        I switched over to the premade image based on kernel 3. Sorry.
        • Z
          zerojay
          Updated the method of getting full screen on advmame to allow it to be automatic and a bit more... proper.
          • Y
            yaazzz
            Does anyone has been able to get scummvm working on xu4. Emulator install should be in "opt" section according to scumm.sh file but it is not.
            • Z
              zerojay @yaazzz
              @yaazzz It's likely masked out with a !mali flag. You can remove it and you should then see it show up in RetroPie-Setup. Try installing it and let us know if it works.
              Y 1 Reply Last reply Reply Quote 0
              • Y
                yaazzz @zerojay
                @zerojay said in Adventures with ODROID XU4 and RetroPie:
                Thank you : that's was the trick. Everything went well : compilation and game launch. I only need To understand how To use the Ds3 with scumm now.
                  BuZz administrators @yaazzz
                  @yaazzz if it works fine, I can enable scummvm for mali targets. Thanks.
                  • Y
                    yaazzz
                    Good morning. I tried to compile Dolphin but it seems I brake the system as I got the following messages :
                    lvl0: Error creating SDL window!
                    Could not initialize EGL
                    lvl0: Renerer failed to initialize!
                    lvl0: Windows failed to initialize!
                    Before touching anything I would like to get your feedback on what is the best solution to recover.
                    • Z
                      zerojay
                      You upgraded your version of SDL2 to whatever is latest in Ubuntu and therefore broke emulationstation, most likely. You'll have to run the installation again to get the original SDL2 installed.
                      I'm not sure why you are compiling Dolphin as I really don't see it being something usable on an ODroid XU4.
                      • Y
                        yaazzz @zerojay
                        Hi, thank you for this feedback. You are Right I don't know why sometimes I am so stupid :) So I tried what you suggest without success. By the way as I didn't reboot after the scumm install please let me check again if it is not the origin of the brake.
                        For people having a cloushell please disconnect the disk and cloudshell for the first boot, make :
                        apt-get update
                        apt-get upgrade
                        apt-get dist-upgrade
                        apt-get install linux-image-xu3
                        poweroff
                        Then reconnect USB and connector to the cloudshell.
                        • Y
                          yaazzz
                          I confirm it is working without the !mali flag. Enjoy!
                          • E
                            Elwro
                            Hi,
                            I have problems with RetroPie on XU4 too.
                            For example, on Ubuntu 18.04, I can't build RetroArch :
                            LD retroarch
                            obj-unix/release/gfx/video_driver.o : Dans la fonction « video_context_driver_find_prev_driver » :
                            video_driver.c:(.text+0x54f4) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                            obj-unix/release/gfx/video_driver.o : Dans la fonction « video_context_driver_find_next_driver » :
                            video_driver.c:(.text+0x55ec) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                            obj-unix/release/gfx/video_driver.o : Dans la fonction « video_context_driver_init_first » :
                            video_driver.c:(.text+0x573c) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                            obj-unix/release/gfx/video_driver.o:(.data.rel.ro+0x10) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                            collect2: error: ld returned 1 exit status
                            Makefile:187: recipe for target 'retroarch' failed
                            make: *** [retroarch] Error 1
                            ~/RetroPie-Setup
                            Could not successfully build retroarch - RetroArch - frontend to the libretro emulator cores - required by all lr-* emulators (/home/odroid/RetroPie-Setup/tmp/build/retroarch/retroarch not found).
                            • E
                              Elwro
                              lr-mupen64plus :
                              /usr/bin/arm-linux-gnueabihf-ld : ne peut trouver -lGLESv2
                              Makefile:304: recipe for target 'mupen64plus_libretro.so' failed
                              make: *** [mupen64plus_libretro.so] Error 1
                              Removing additional swap
                              ~/RetroPie-Setup
                              Could not successfully build lr-mupen64plus - N64 emu - Mupen64Plus + GLideN64 for libretro (/home/odroid/RetroPie-Setup/tmp/build/lr-mupen64plus/mupen64plus_libretro.so not found).
                              • E
                                Elwro
                                PPSSPP :
                                cc1plus: warning: unrecognized command line option ‘-Wno-deprecated-register’
                                CMakeFiles/native.dir/build.make:86: recipe for target 'CMakeFiles/native.dir/ext/native/base/PCMain.cpp.o' failed
                                make[2]: *** [CMakeFiles/native.dir/ext/native/base/PCMain.cpp.o] Error 1
                                CMakeFiles/Makefile2:163: recipe for target 'CMakeFiles/native.dir/all' failed
                                make[1]: *** [CMakeFiles/native.dir/all] Error 2
                                make[1]: *** Attente des tâches non terminées....
                                [ 22%] Linking CXX static library ../../lib/libspirv-cross-core.a
                                [ 22%] Built target spirv-cross-core
                                Makefile:129: recipe for target 'all' failed
                                make: *** [all] Error 2
                                ~/RetroPie-Setup
                                Could not successfully build ppsspp - PlayStation Portable emulator PPSSPP (/home/odroid/RetroPie-Setup/tmp/build/ppsspp/ppsspp/PPSSPPSDL not found).
                                • Z
                                  zerojay
                                  @elwro said in Adventures with ODROID XU4 and RetroPie:
                                  Use the ORA image instead.
                                  • E
                                    Elwro @zerojay
                                    @zerojay
                                    Ok, thank, too bad.
