    N64 roms will not work...
    n64emulator
    23 Posts 8 Posters 6.5k Views
      colking
      I've tried changing the n64 emulators but still nothing. A few times I could hear the volume of Super MARIO 64 but now video. What can I do to improve this?
      I'm a noob here.
        mitu Global Moderator @colking
        @colking https://retropie.org.uk/forum/topic/3/read-this-first - please give more details about your setup. Are you using a RPI or you're on a PC ?
          colking @mitu
          @mitu - I'm using raspberry pi 3. What else do you need?
          rbakerR mituM 2 Replies Last reply Reply Quote 0
          • rbakerR
            rbaker @colking
            @colking How about the information that you agreed to provide before signing up? https://retropie.org.uk/forum/topic/3/read-this-first as requested above?
              @colking The page I pointed out has some pointers for useful info - what emulator are you using, what's your power source, any details in the logs, how did you install the system, RetroPie version, etc.
              You need to provide more info on your system and setup, because what you're experiencing is something specific to your system and it will help us find the source of the problem.
              C 2 Replies Last reply Reply Quote 0
                colking @mitu
                @mitu it's an image (128gb) attract. I have the real power supply for the pi 3. Version of retropie is 4.3.8. I believe that's the newest one.
                  @colking said in N64 roms will not work...:
                  In this case, please install the image from retropie.org.uk/download first and try again.
                    colking @mitu
                    @mitu I've tried all of the n64 emulators that are available to install on retropie. 5 or 6 of them.
                    jonnykeshJ rbakerR 2 Replies Last reply Reply Quote 0
                    • jonnykeshJ
                      jonnykesh @colking
                      @colking Third party images are not supported on the forum. No one here has any idea how these are configured. You should ask "Rey", I assume it's his you are using.
                      • rbakerR
                        rbaker @colking
                        The answer is then simple, you do not have N64 roms.
                          colking @jonnykesh
                          @jonnykesh yes... thank you.
                            colking @mitu
                            @mitu I keep trying to download the image from that link and it keeps failing...
                              colking @rbaker
                              @rbaker I do have several roms. Been trying super Mario 64 and only the volume works. It allows me to play but it's a black screen...
                                @colking Can't help you there, download works for me, so it's not the site or the file. How are you downloading the file ? Browser, any download program ?
                                • jonnykeshJ
                                  jonnykesh @colking
                                  @colking Just downloaded it as a test. No problems and downloaded in about a minute or so. Try a different browser.
                                    colking @mitu
                                    @mitu I'll try another browser when I get home tonight. Thanks
                                      colking @jonnykesh
                                      @jonnykesh I still can't download from the retropie site... I've downloaded several ipmages elsewhere though. I just can't seem to download from this site... wtf?!?! Keep failing after about 60mb. yet I've downloaded a 128gb, 64gb and 16gb image files from other sites... tried every browser and still nothing...
                                      BobHarrisB 1 Reply Last reply Reply Quote 0
                                      • BobHarrisB
                                        BobHarris @colking
                                        @colking
                                        https://retropie.org.uk/forum/topic/4400/torrent-download-retropie
                                        Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
                                          Clyde
                                          If your Retropie SD card has enough free space for the image and your Pi has internet access, you could try to download the image from Retropie's command console and copy it to your PC from there. To do that, exit Emulation Station and enter the following command:
                                          wget https://github.com/RetroPie/RetroPie-Setup/releases/download/4.3/retropie-4.3-rpi2_rpi3.img.gz
                                          That should download the image to the home directory of Retropie's standard user pi. The docs tell you how to transfer files via network or an usb stick from the Pi to your PC for further installation.
                                            colking @BobHarris
                                            @bobharris tried that link. says the file was deleted. :(
