Controller Profiles per Emulator
  • I am relatively new here, but came across an issue with the controllers i purchased with my raspberry pi 3. I have essentially N64 controllers, and thought that would be more than adequate for all the gaming I had planned, but I find myself often having to reconfigure the input whenever i switch between NES/SNES...is there an option to develop profiles for specific systems so that the input is automatically mapped to the preferred button configuration for the system?
  • Global Moderator
    @bisantium
    Any of the 'lr-' (RetroArch) emulator cores can easily be remapped per system. When in game, pull up the menu (hotkey+x). Next select 'Quick Menu' and then 'Controls'. Rework them to your liking and then be sure to select the save option for the system from the same menu.
