    *SOLVED* 240p per emulator (run command setting) possible?
    240prun commandpervideomodes
    25 Posts 8 Posters 13.3k Views
      pjft @youxia
      @youxia I was going for composite.
      Y 1 Reply Last reply Reply Quote 0
      • Y
        youxia @pjft
        @pjft Then I recommend reading about these 2 methods first, the ES look is the least of your worries ;)
        https://retropie.org.uk/forum/topic/18624/custom-configs-for-crt-using-the-built-in-composite-out
        https://retropie.org.uk/forum/topic/11628/240p-and-mame-scaling/12
          pjft @youxia
          @youxia Thanks - I'll look into it!
            molton
            I've been looking into this a bit recently. I find that the default settings look pretty good in 240p with bilinear filtering on, but I wanted to get really accurate results so I compared the real NES hardware output to the raspberry Pi composite out in 240p.
              molton
              for NES my CRT likes
              -240p screen format
              -640x480 render resolution for the screen format
              -717x552 (5 x -40 offset) retroarch scaling resolution
              -bilinear filtering set to off
              For SNES I use a 702x496 retroarch custom scaling resolution with a 12 x -8 offset and bilinear filtering on. Genesis looks pretty good with bilinear filtering on and standard 4:3 resolution
