    Retropie Blinkt! LED Project
    retro pieled lightscodingnoobie
    4 Posts 3 Posters 1.4k Views
      topher_csr
      https://imgur.com/a/V9gM7
      A little explanation on this.
      I used a Blinkt! LED board that clips onto the Pi3 to change colors depending on what system is running. so it boots to a white light, then changes colors depending on the game played. the break down is as follows
      NES=Red
      SNES=Purple
      GBC=Green
      GBA= Orange
      N64= Red, Green, Yellow, Blue (logo colors)
      SG-1000= Blue
      SG 32=Aqua
      Sega CD=greenish blue
      PS1= Yellow
      it was a fun project to get my feet wet in coding. it will be short lived as I have a Unicorn Hat HD coming soon :)
      • herb_fargusH
        herb_fargus administrators @topher_csr
        @topher_csr neat! I imagine this just plugs into the GPIO? A lot cheaper than the sense hat, maybe I'll work my way up to it.
        I've got a load of chinese RGB led spools but not the most conducive for control with the pi with my setup. I also got a 3dxmas led tree from the pihut that was pretty fun but I ran into roadblocks trying to figure out merging the alsa driver with the GPIO for a Vu meter
        If you haven't already you should post your code on GitHub or something, I may try this out myself one day if/when I find motivation
          topher_csr
          it is super affordable and plugs right into the GPIO! The kit is this one, but i got it at Microcenter for the same price. Would have loved to buy it from them, but shipping was a lot from the UK.
          https://shop.pimoroni.com/products/blinkt
          I have never put anything on github, but used it a lot, i did not think it would be that useful, but i will look into it!
          • spruce_m00seS
            spruce_m00se
            I have a question,
            could you manage to get a GPIO output to toggle from high to low or vice versa when something happens in the game? are there any methods to detect if gameover or highscore happens?
            I ask because I have RGB mood lighting on my cabinet, and would love to make it flash and strobe etc if you die or get a highscore etc.
            I understand that detecting an emulator starting and detecting what happens inside the emulator are two different things, but you dont get if you dont ask :)
