    First time poster in need of help: Pi3 not booting
    not bootingsd card
    45 Posts 5 Posters 9.1k Views
      jbryan1984
      Wow guys. You wanna know what the problem was the entire time? The NEPSI classic NES box! Not sure if you are familiar but it comes with plug ins that you like plug in to your usb ports on the pi, this makes it so you can turn it on and off like the original NES. So, when my pi is plugged into the NEPSI plugs ins, it WILL NOT boot! But not hooked up, it boots just fine and goes into ES. I have plugged it in and unplugged it 3 times just to be sure. That is crazy.
        grant2258 Banned
        it authentic another one on the lessons pile bottom line is it works :) not get your old classics on and get some blisters on your skin lol
          mitu Global Moderator @jbryan1984
          @jbryan1984 Then you might not get enough power through the case adapter, that's not the first time when this pops up.
            jbryan1984
            Yeah just sucks cause the case was 25 bucks.
            ByteThisB 1 Reply Last reply Reply Quote 0
            • ByteThisB
              ByteThis @jbryan1984
              @jbryan1984 Wobbly pop (beer) money ! haha
