    MCP23017 and Retropie, some problem appears
    mcp23017gpiocontrollerrecalbox
    40 Posts 5 Posters 8.2k Views
      mitu Global Moderator @StoneSet
      @stoneset Are you using Berryboot or the RetroPie image ? How was your system installed ?
        StoneSet
        I used the retropie image, i burn the img with etcher
        Best regards,
        http://stoneset.github.io
          @stoneset The error comes from:
          Module build for the currently running kernel was skipped since the
          kernel source for this kernel does not seem to be installed.
          However, you seem to be using an older version of the RetroPie-Setup script. Update the script and the underlying OS packages, then try again.
            StoneSet
            Okay i updated the script, but now I get a kernel error, I do not have the right update
            Best regards,
              @stoneset Did you update also the OS packages - including the kernel ? If so, then reboot so that the new kernel is picked up.
                StoneSet
                I don't know, I will try
                Best regards,
                  StoneSet
                  Okay !! I successefully installed the driver !
                  But now i have got another problem :
                  When i run "jstest /dev/input/js0"
                  Axes: 0: 0 1: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off 8:off 9:off 10:off 11:off
                  Only :
                  • Buttons 6 : on
                  • Buttons 8 : on
                  I also try to add a 10kohm to the button
                  (This shematics : alt text without the led
                  And I run properly everythin !
                  link text
                  I think, the map isn't correct with my configuration :
                  sudo modprobe mk_arcade_joystick_rpi map=1,0x20
                  Any suggestion ?
                  Best regards,
                  rbakerR simonsterS 2 Replies Last reply Reply Quote 0
                  • rbakerR
                    rbaker @StoneSet
                    @stoneset On a breadboard like that above, the power rails do not go all the way along, only half way.
                      StoneSet
                      So ?
                      Best regards,
                      • rbakerR
                        rbaker @StoneSet
                        @stoneset There are components on both sides of the gap - if there is a gap - on your board.
                        • simonsterS
                          simonster @StoneSet
                          @stoneset
                          Use sudo i2cdetect -y 1 to get the value for the map figure.
                          What is the resistor connected from 5v to pin 28 for, are you attempting to pull it high? According to the datasheet the chip does this automatically. Also you appear to have the led and resistor connected to pin 21 (up) and the reset pin connected to 5v.
                          The pinout is as in this image: https://raw.githubusercontent.com/recalbox/mk_arcade_joystick_rpi/master/wiki/images/mk_joystick_arcade_mcp23017.png
                            StoneSet
                            Hi,
                            This is my schematics :
                            Where i have to put the resistor ?
                            thanks a lot !
                            Best regards,
                              StoneSet
                              Okay good news, i have found the problem :
                              I read this "It uses internal pull-ups of RPi and of MCP23017, so all switches must be directly connected to its corresponding GPIO and to the ground."
                              So no resistor needed
                              And, the problem is'nt hardware, but software !
                              Some pictures :
                              I think the problem is when i do :
                              "sudo modprobe mk_arcade_joystick_rpi map=1,0x20"
                              The driver does not work with the mcp23017 and continues to work on the gpio rpi
                              thanks,
                              If some one can help me
                              Best regards,
                              simonsterS 1 Reply Last reply Reply Quote 0
                              • simonsterS
                                simonster @StoneSet
                                @stoneset
                                @stoneset said in [MCP23017 and Retropie, some problem appears]
                                thanks,
                                This command will make js0 map to GPIO pins as per normal mk_arcade_joystick and js1 map to the mcp23017.
                                You need to do the following to map it as js0:
                                sudo modprobe mk_arcade_joystick_rpi map=0x20
                                Why do you have the reset pin on the MCP23017 connected to 3.3V, I've never seen this done.
                                  StoneSet
                                  Hi,
                                  Thanks for your reply, finally it work !!
                                  Thanks a lot everyone !
                                  (I will write a manual, "how to use MCP23017 on RetroPie")
                                  Best regards,
                                  • simonsterS
                                    simonster
                                    If you want to attach further controllers using addition mcp23017 chips, to can pair all the wires to the Pi and just change it so on of the A0,A1 or A2 leads are pulled high. Then use i2cdetect to find its value and load it using map=0x20, 0x22 (or whatever the address is) and it will connect as P2
                                    I've had 4 players connected like this. Did you leave the reset pin attached to 3.3v? I've just tried on mine and nothing works when I pull that pin high.
                                      StoneSet
                                      Hi,
                                      Thanks for you reply,
                                      No i didn't leave the 3.3V reset pin on the MCp23017. It work perfectly !
                                      Best regards,
                                      • N
                                        nickstr138
                                        Hi @StoneSet
                                        Did you happen to write the manual "how to use MCP23017 on RetroPie?"
                                        I appear to be stuck in the same place you were.
                                        Thank you!!
                                        • simonsterS
                                          simonster @nickstr138
                                          @nickstr138
                                          I keep trying to write a detailed manual on this stuff, but have been really busy with work of late.
                                          What is the issue you are having?
                                            StoneSet
                                            Hi everyone
                                            @nickstr138 I have created a "driver" for this, check this out :
                                            https://github.com/retrobox/console-modules/blob/master/installinputsdriver.sh
                                            Regards
                                            Best regards,
