    Controller illustrator tool...for testing control layout.
    controllercontroller conflibretrofeature request
    1 Posts 1 Posters 524 Views
      Tweeksy
      Apologies if this is not the correct way to suggest something like this (first post, so let me off easy!?).
      I have a PS3 controller used Wirelessly with Retropie 4.3 and it works really well. I decided to try out N64 emulation with a few noms and it gets confusing as to which keys are which (compared to an N64 controller).
      Although the documentation does show you, I thought a handy tool for each emulator section for each console, could show you an illustration of that consoles controller and show you the buttons being pressed as you press the corresponding button on your controller. i.e. I see an N64 controller not the screen and when I press the X button on my PS3 controller, I see the equivalent on the screen.
      I suppose this would only work with liberetto with a consistent controller config??
